Topic: Trouble with attachinterrupts (Read 3233 times) previous topic - next topic
mrandersen
I am using this to sense when a magnet passes the hall effect sensors. They are both trying to do the same thing. The below code works:
const float kDistance = 0.063;
unsigned long timeStarted;
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  digitalWrite(2, HIGH);
  digitalWrite(3, HIGH);
  timeStarted = 0;
  if (!digitalRead(2) && !timeStarted)
   timeStarted = millis();
   Serial.println("Start time");
  if (!digitalRead(3) && timeStarted)
  float deltaTime = (millis()-timeStarted)/1000.0;
  float velocity = kDistance/deltaTime;
  Serial.print("Velocity = ");
  Serial.println(velocity, DEC);
  Serial.print("Time = ");
  Serial.println(deltaTime, DEC);
  timeStarted = 0;
  Serial.println("End time");
However this code does not - It is using attachinterrupts which would work much better, especially if I added more to my code and made it more complex.
  timeStarted = 0;
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  digitalWrite (2, HIGH);
  digitalWrite (3, HIGH);
  attachInterrupt(0, startTime, FALLING);
  attachInterrupt(1, endTime, FALLING);
void startTime()
  if (!timeStarted)
void endTime()
  if (timeStarted)
  timeStarted = 0;
   Serial.println("Testing Error!");
Thanks in advance!
ElectronicsNoobie
If I remember correctly you cant make calls to Serial from within an interrupt. I would remove them from your interrupt functions.
retrolefty
That's correct, all further interrupts are disabled once you are inside a ISR function so anything that requires the active use on interrupts (like serial) will just hang inside the ISR. The general rule for writing good effective ISR functions is to keep it simple, just do the bare minimum needed to be done, increment a variable, set a flag, save a value, etc, and do all the heavy lifting in the main loop by testing such flags, or variables to actually do stuff.
Lefty
mrandersen
Thanks, now I have another problem.
When either interrupt triggers both timeStarted and timeEnded are the same...
unsigned long timeStarted = 0;
unsigned long timeEnded = 0;
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  if (timeStarted && timeEnded)
//  float deltaTime = (timeEnded-timeStarted)/1000.0;
//  float velocity = kDistance/deltaTime;
//  Serial.print("Velocity = ");
//  Serial.println(velocity, DEC);
//  Serial.print("Time = ");
//  Serial.println(deltaTime, DEC);
  Serial.println(timeStarted, DEC);
  Serial.println(timeEnded, DEC);
  timeStarted = 0;
  timeEnded = 0;
void startTime()
  if (!timeStarted)
void endTime()
  if (!timeEnded)
    timeEnded = millis();
retrolefty
volatile unsigned long timeStarted = 0;
volatile unsigned long timeEnded = 0;
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  timeStarted = 0;
  timeEnded = 0;
void startTime()
  if (!timeStarted)
void endTime()
  if (!timeEnded)
I think you have to make those two variables 'volatile' as I added to your code above. Give it a try and report back.
http://arduino.cc/en/Reference/Volatile
Lefty
mrandersen
Lefty
I tried this but both variables are still printing as the same number.
retrolefty
Lefty
Well maybe the interrupts are coming faster then you think. Try using micros():
timeStarted = micros();
timeEnded = micros();
Lefty
mrandersen
Lefty
After a further look I realized that one pin is triggering both the start time and end time.
Do you know why one input is triggering start time and end time?
retrolefty
Lefty
Short of a wiring problem, that is not really possible. Can you explain how you have the sensors arranged in relationship to the magnet and how fast the magnet is moving between them?
mrandersen
The signal being generated by the sensors is correct as it works flawlessly in the loop code. The two sensors are about 10cm apart, and the magnet passes by them in about 0.2 seconds. Even after I unplug a sensor, the one pin will still trigger both startTime and endTime.
I appreciate your help.
