Loading...
Pages: [1] 2   Go Down
Author Topic: I2C Pressure Sensor  (Read 1363 times)
Offline Offline
Newbie
View Profile
Hello,
I have a Smartec Pressure sensor that i am trying to get values from and eventually display to a small LCD screen.
http://www.smartec-sensors.com/assets/files/pdf/Datasheets_pressure_sensors/SPD006LIhybN.pdf
I figured the first step would be to get proper data out to the serial monitor.
So far i have the following, but i believe i need some guidance on how to interpret/convert the data to something meaningful smiley
Thanks for your help !!
Pete
Code:
#include "Wire.h"
#define addrs 0x78 // I2C bus address
Wire.begin();
   byte firstbyte;
   byte secbyte;
   Wire.beginTransmission(addrs);
   Wire.write(0);        // move your register pointer back to 0
   Wire.endTransmission();
   Wire.requestFrom(addrs, 2); // contents of your first two registers
   while(Wire.available())          // Check for data from slave
      firstbyte = Wire.read();       // Read press high byte
      secbyte = Wire.read();      // Read press low byte
  Serial.print("first byte  ");
  Serial.print(firstbyte, DEC);
  Serial.print("sec byte  ");
  Serial.println(secbyte, DEC);
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The while loop is dodgy - you need to wait for each byte in turn, if data isn't available you'll skip the loop entirely and not wait.
Code:
  while (Wire.available() < 2)
Logged
Offline Offline
Newbie
View Profile
Mark i appreciate the info..
I went ahead and modified the code as you suggested to read,
Code:
  while (Wire.available() <2 )
It seems to me that it hangs around the While loop since the Serial Monitor doesn't show anything.
If i remove the "<2" i get data being spat out, although i don't think its correct since regardless of the pressure it shows the same numerical values ?
Ideas, Suggestions ?
Pete
Logged
Offline Offline
Newbie
View Profile
I am still getting gibberish on the serial monitor, i think it has something to do with how i am declaring the stored data value/type and how long it is ?
Can someone look at the above sensor data sheet and offer some insight ?
I would really appreciate it smiley Happy New Years to Everyone !!
Pete
Logged
Offline Offline
Newbie
View Profile
Anyone, some help would really be appreciated  smiley
Pete
Logged
Offline Offline
Newbie
View Profile
The way I read that datasheet is that to get the pressure byte back from the sensor, you need to send a READ request, which is a 1 after the address. You're sending 0.
Code:
Change the second line to
Code:
   Wire.write(1);
and see what happens.
Found that in the Addressing section on page 3.
Hope this helps.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
what you made of it
Code:
is not what MarkT porposed
Code:
read carefully!
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
I appreciate everyone's responses !!
I have modified the code as follows and getting nothing on the Serial Monitor..
Code:
#include "Wire.h"
Wire.begin();
   byte firstbyte;
   byte secbyte;
   Wire.write(1);        // move your register pointer back to 0
  Serial.print(firstbyte, BIN);
  Serial.print("  sec byte ");
  Serial.println(secbyte, BIN);
If i change the while loop to the following below, i get this on the serial monitor " first byte 11111111  sec byte 11111111", which still isn't right  ?
Code:
   while (Wire.available() )
I appreciate the help guys a lot..
Pete
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Code:
is this right?
check it with :
Code:
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
  Serial.begin (115200);
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
from - http://www.gammon.com.au/forum/?id=10896 - a well documented resource!
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
I ran the below sketch Rob and  it gave me nothing on the serial monitor, but i ran a newer version of the scanner dated June2012 i found on the Arduino resource page and it gave me this..
Quote
I2C Scanner
Scanning...
I2C device found at address 0x78 !
done
Ideas ?
Thanks Much !!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
broken device?
do you have other I2C devices working?
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Well i have access to their sensor acquisition board (see link below) and when i connect the same sensor i get meaningful data ?
http://www.smartec-sensors.com/assets/files/pdf/manuals/SMTAS02I2CN.PDF
Pete
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Can you try this sketch? and post its output?
Code:
#include "Wire.h"
  Wire.begin();
  byte b;
  Wire.write(1);
  int x = Wire.endTransmission();
  Serial.println(x, DEC);
    b = Wire.read();
    Serial.println(b, dec);
« Last Edit: January 07, 2013, 01:10:05 pm by robtillaart » Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
I ran the sketch you posted Rob and i get all Zeros on the serial monitor..
Quote
0
0
0
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
The first 0  means success:   // int x = Wire.endTransmission(); so that part seems to work, however it does not give the 2 bytes.
new sketch, added some comments and missing request form
Code:
#include "Wire.h"
  Wire.begin();
  byte b;
  Wire.write(1);
  Serial.print("endTransmission: ");
  Wire.requestFrom(addrs, 2); // might be useful to request some bytes..
  while (Wire.available() < 2);
  Serial.print("byte 1: ");
  b = Wire.read();
  Serial.println(b, DEC);
  Serial.print("byte 2: ");
  b = Wire.read();
Logged
Rob Tillaart
Pages: [1] 2   Go Up
Print
Jump to:
