Topic: I2C Pressure Sensor (Read 11575 times) previous topic - next topic
pasta1234
Hello,
I have a Smartec Pressure sensor that i am trying to get values from and eventually display to a small LCD screen.
http://www.smartec-sensors.com/assets/files/pdf/Datasheets_pressure_sensors/SPD006LIhybN.pdf
I figured the first step would be to get proper data out to the serial monitor.
So far i have the following, but i believe i need some guidance on how to interpret/convert the data to something meaningful :)
Thanks for your help !!
Pete
#include "Wire.h"
#define addrs 0x78 // I2C bus address
Wire.begin();
   byte firstbyte;
   byte secbyte;
   Wire.beginTransmission(addrs);
   Wire.write(0);        // move your register pointer back to 0
   Wire.endTransmission();
   Wire.requestFrom(addrs, 2); // contents of your first two registers
   while(Wire.available())          // Check for data from slave
      firstbyte = Wire.read();       // Read press high byte
      secbyte = Wire.read();      // Read press low byte
  Serial.print("first byte  ");
  Serial.print(firstbyte, DEC);
  Serial.print("sec byte  ");
  Serial.println(secbyte, DEC);
MarkT
The while loop is dodgy - you need to wait for each byte in turn, if data isn't available you'll skip the loop entirely and not wait.
  while (Wire.available() < 2)
pasta1234
Mark i appreciate the info..
I went ahead and modified the code as you suggested to read,
  while (Wire.available() <2 )
It seems to me that it hangs around the While loop since the Serial Monitor doesn't show anything.
If i remove the "<2" i get data being spat out, although i don't think its correct since regardless of the pressure it shows the same numerical values ?
Ideas, Suggestions ?
Pete
pasta1234
I am still getting gibberish on the serial monitor, i think it has something to do with how i am declaring the stored data value/type and how long it is ?
Can someone look at the above sensor data sheet and offer some insight ?
I would really appreciate it :) Happy New Years to Everyone !!
Pete
pasta1234
Anyone, some help would really be appreciated  :)
Pete
TrainMan186
The way I read that datasheet is that to get the pressure byte back from the sensor, you need to send a READ request, which is a 1 after the address. You're sending 0.
Change the second line to
   Wire.write(1); and see what happens.
Found that in the Addressing section on page 3.
Hope this helps.
robtillaart
what you made of it
is not what MarkT porposed
read carefully!
Rob Tillaart
pasta1234
I appreciate everyone's responses !!
I have modified the code as follows and getting nothing on the Serial Monitor..
#include "Wire.h"
Wire.begin();
   byte firstbyte;
   byte secbyte;
   Wire.write(1);        // move your register pointer back to 0
  Serial.print(firstbyte, BIN);
  Serial.print("  sec byte ");
  Serial.println(secbyte, BIN);
If i change the while loop to the following below, i get this on the serial monitor " first byte 11111111  sec byte 11111111", which still isn't right  ?
   while (Wire.available() )
I appreciate the help guys a lot..
Pete
robtillaart
is this right?
check it with :
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
  Serial.begin (115200);
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
from - http://www.gammon.com.au/forum/?id=10896 - a well documented resource!
Rob Tillaart
pasta1234
I ran the below sketch Rob and  it gave me nothing on the serial monitor, but i ran a newer version of the scanner dated June2012 i found on the Arduino resource page and it gave me this..
I2C Scanner
Scanning...
I2C device found at address 0x78 !
done
Ideas ?
Thanks Much !!
robtillaart
broken device?
do you have other I2C devices working?
Rob Tillaart
pasta1234
Well i have access to their sensor acquisition board (see link below) and when i connect the same sensor i get meaningful data ?
http://www.smartec-sensors.com/assets/files/pdf/manuals/SMTAS02I2CN.PDF
Pete
robtillaart
#12
Jan 07, 2013, 07:06 pm Last Edit: Jan 07, 2013, 07:10 pm by robtillaart Reason: 1
Can you try this sketch? and post its output?
#include "Wire.h"
 Wire.begin();
 byte b;
 Wire.write(1);
 int x = Wire.endTransmission();
  Serial.println();
 Serial.println(x, DEC);
   b = Wire.read();
   Serial.println(b, dec);
Rob Tillaart
pasta1234
I ran the sketch you posted Rob and i get all Zeros on the serial monitor..
robtillaart
The first 0  means success:   // int x = Wire.endTransmission(); so that part seems to work, however it does not give the 2 bytes.
new sketch, added some comments and missing request form
#include "Wire.h"
  Wire.begin();
  byte b;
  Wire.write(1);
  Serial.print("endTransmission: ");
  Wire.requestFrom(addrs, 2); // might be useful to request some bytes..
  while (Wire.available() < 2);
  Serial.print("byte 1: ");
  b = Wire.read();
  Serial.println(b, DEC);
  Serial.print("byte 2: ");
  b = Wire.read();
  Serial.println();
Rob Tillaart
