Topic: FT232RL (Read 2665 times) previous topic - next topic
Vincent19
Hey guys, recently I just bought a FT232RL chip from RS. So, I would like to ask, how can I connect that to my AVR chip so that I can program my AVR chip just through the USB cable ?
Any schematic ?
Thank you
cmagagna
What is RS? Did you buy a bare chip or a board?
Look at the Duemilanove schematic for an example of connecting them, it's not very complicated at all.
Vincent19
Erm, is that we just connect CCC, gnd, txd and rxd to the avr chip?
Graynomad
Here's the FTDI part of a schematic I used for a board a while back.
I'm not sure if it's the FT232RL but I think so.
______
Rob
Vincent19
So the bottom left ( DTR, TXD and RXD is connected to the atmega ? connect to which pin of atmega ?
Thank you
Graynomad
#5
Oct 08, 2012, 02:59 pm Last Edit: Oct 08, 2012, 03:01 pm by Graynomad Reason: 1
The FT Txd and Rxd connect to the Atmega Rxd and Txd. Look at the arrows on the chip to see the direction of the signals.
The left side of C5 goes to Reset. I would compare this against an Arduino schematic as well.
_____
Rob
Vincent19
So, just this 3 pins is connected to the atmega ? Excluded the VCC and GND to chip
Vincent19
_____
Rob
What is the thing in 500mA ?? Curious
retrolefty
_____
Rob
That is a 500ma fuse to protect your PC in case you ever try to draw too much current from the USB +5vdc voltage source.
Lefty
Vincent19
https://www.sparkfun.com/products/10166
This one ?
Graynomad
Yep.
This one ?
Not normally although I guess it would work. There are many SMD fuses around that people usually use. This sort of thing
http://au.mouser.com/ProductDetail/Littelfuse/1210L380SLYR/?qs=sGAEpiMZZMusLSpKoAsBX4%252b2FXOFNEba
______
Rob
