Topic: Alphanumeric LED Display easy for a beginner? (Read 3875 times) previous topic - next topic
JulianDave
I am new to Arduino (but not programming) and would like to chain together 4 or 5 of these 1 inch alphanumeric display modules:
http://www.embeddedadventures.com/16_segment_led_display_DSP-0401B-BLUE.html
These seem a lot less expensive than what can be put together at sparkfun, using:
https://www.sparkfun.com/products/9933
https://www.sparkfun.com/products/10103
but the Spark Fun LEDs come with a library and Arduino code. I haven't found any specific examples using the displays from Embedded Adventures.
Should using these with an Arduino Uno be fairly straightforward? Maybe similar in use to the Spark Fun LEDs?
Thanks.
fungus
They have built in TLC5926 controller so it should be very simple to use, it's just a serial interface.
BulletMagnet83
I have the 14 segment x 8 digit version, it was pretty easy to work with once I'd worked out a few kinks with my code. The hardest part was finding the time and motivation to sit down and work out all the character codes :p actually getting it working wasn't too hard.
JulianDave
Great! Thank you both for the responses. I didn't want to buy something that I was going to have a hard time with.
ianharris
Tutorials now available to show how to connect an arduino to a DSP-0401B with sample code and videos.
kind regards
Ian.
