Loading...
Pages: [1]   Go Down
Author Topic: Arduino UNO+Motor Shield DC motor controlling !  (Read 546 times)
Offline Offline
Newbie
View Profile
Hello,
I have an Arduino UNO R3 and Motor Shield. I want to control a dc motor via motor shield.
I am new at programming.
Are there any control program example  for me ? Thank you.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Useful resource
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
I found this code for using one DC motor but the motor did not work. I got this error : avrdude: stk500_getsync(): not in sync: resp=0x00
How can I fix this code ?
Code:
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
void loop(){
  //forward @ full speed
  digitalWrite(12, HIGH); //Establishes forward direction of Channel A
  digitalWrite(9, LOW);   //Disengage the Brake for Channel A
  analogWrite(3, 128);   //Spins the motor on Channel A at full speed
  delay(3000);
  digitalWrite(9, HIGH); //Eengage the Brake for Channel A
  //backward @ half speed
  digitalWrite(12, LOW); //Establishes backward direction of Channel A
  analogWrite(3, 123);   //Spins the motor on Channel A at half speed
  delay(3000);
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
There's nothing wrong with the code (well, nothing syntactically wrong) - that's an upload error; did you select and connect the correct board?
« Last Edit: October 08, 2012, 06:43:06 am by AWOL » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
And, did you make sure that there is nothing connected to pins 0 and 1 (directly or via any shield)?
Logged
Offline Offline
Newbie
View Profile
Yes, I selected the correct board (Arduino UNO R3).
Logged
Offline Offline
Newbie
View Profile
Quote
There is nothing connected any pins on shield. Just USB and motor connections on shield (A+ A-) are connected
Logged
Offline Offline
Newbie
View Profile
Is there any idea ?  smiley-confuse
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Is there any idea ?
I have a couple. First, you might try telling us, via a link, just which shield you have.
Second, you might try removing the shield while uploading the sketch.
Logged
Pages: [1]   Go Up
Print
Jump to:
