Author Topic: Rs232 comunication with an inclinometer 0729-1752  (Read 342 times)
Good morning all,
I'm trying to comunicate the arduino with an inclinometer (rs 232 comunication, sensor have 4 pins vcc, gnd, rx, tx so a found that the comunication should be easy) then i need to send to the sensor what i want ('X' or 88 in ascii, then 'Y' or 89 in ascii) and recive the angles.
I tried with softwareserial with no results.
I think hardwareserial should work but i dont realy know how to use it. I have searched for it but i just found ready examples that i didnt understand nothing. Have anyone any tutorial, or something explained in detail ?
Do you have any other ideia how can i comunicate to the sensor ?
The sensor is the inclinometer 0729-1752, and one of the codes using Softwareserial that i tried to use was that:
#include <SoftwareSerial.h>
SoftwareSerial portOne(2, 3);
int ax = 88;
int ay = 89;
    portOne.begin(9600);
  portOne.write(ax);
  float x = portOne.read();
  delay(100);
  portOne.write(ay);
  float y = portOne.read();
  delay(100);
  Serial.print(x);
  Serial.println(y);
Thanks for all, any help with be very welcome.
UK
What are you using for RS232 level conversion?
The "read" method returns an "int" representing a single character, not a floating point number.
You need to buffer the characters representing the float, and use an explicit method like "atof" to convert from ASCII.
« Last Edit: October 08, 2012, 07:58:27 am by AWOL » Logged
I dont really know if a level conversion is needed cause i guess the sensor already have a level converter,
And i did comunicate the sensor with the pc using realterm (but unfortunately i cannot use a pc for the aplication) without using a level converter, thats why i think its a software problem.
UK
RS232 communication to an Arduino does need a signal level converter.
RSR23 levels can be up to +/- 25 volts, and are inverted with respect to the TTL levels the Arduino expects.
Yeah, thats problaby the problem, so do i need to recive int by int and create a buffer for that ? the signal from the sensor is 16bits for angles and 10bits for temperature.
UK
In which case, I don't see why you're trying to read a float.
Do you have a link to this device?
Sure,
http://www.frederickscom.com/pdf/6200-006-rs232.pdf
thats the mini signal conditioner board, the sensor is sold already on it by the manufacter as the 0729-1752 that you can see here http://www.frederickscom.com/pdf/0729-17XX%202009-03-03.pdf, but the instructions is in the first link.
UK
OK, so it is RS232, so you do need level conversion.
It doesn't say whether the result is big- or little-endian, you'll need to figure that out.
You just read two bytes and either shift the most-significant left by 8 bits, or multiply by 256.
No floats involved.
Ok i will try that, working or not i will post it here then,
thanks a lot.
UK
BTW
int ax = 88;
int ay = 89;
is much easier to read as
char xCommand = 'X';
char yCommand = 'Y';
(or whatever "Command" translates to in Portugese)
BTW
int ax = 88;
int ay = 89;
yeah this i already tried ^^
