Loading...
Pages: [1]   Go Down
Author Topic: Control Two LED's with one button  (Read 817 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am having a hard time finding an example on how to control two LED's with one button.
What I would like to do is turn one LED on with a button press and then on the second button press turn the first LED off and turn the second LED on.
I am thinking that I need to a create a variable that increments each time the button is pressed.  Push button once var = 1 turns LED 1 on.  Button press second time var = 2 turns LED1 off and LED2 on then resets var back to 0.  Seems overly complicated though and I want to minimize the code as much as possible.
Any guidance would be greatly appreciated.
Logged
Scunthorpe, UK
Offline Offline
Full Member
"to make something better we have to break it"
View Profile
Have a look at the statechangedetection example that comes with the Arduino software. With a few little changes this can be done very easily.
« Last Edit: September 27, 2012, 03:53:20 pm by Pavilion1984 » Logged
Offline Offline
Newbie
View Profile
got pretty bored so I made this
it compiles fine on my machine so if you have any errors I will fix them
Code:
int switchPin = 2;              // switch is connected to pin 2
    int led1Pin = 8;
    int led2pin = 9;
    int val;                        // variable for reading the pin status
    int val2;                       // variable for reading the delayed status
    int buttonState;                // variable to hold the button state
    int Mode = 0;              // What mode is the light in?
      pinMode(switchPin, INPUT);    // Set the switch pin as input
      pinMode(led1Pin, OUTPUT);
      pinMode(led2pin, OUTPUT);
      buttonState = digitalRead(switchPin);   // read the initial state
    void loop(){
      val = digitalRead(switchPin);      // read input value and store it in val
      delay(10);                         // 10 milliseconds is a good amount of time
      val2 = digitalRead(switchPin);     // read the input again to check for bounces
      if (val == val2) {                 // make sure we got 2 consistant readings!
        if (val != buttonState) {          // the button state has changed!
          if (val == LOW) {                // check if the button is pressed
            if (Mode == 0) {
              Mode = 1;
                if (Mode == 1) {
                Mode = 2;
                if (Mode == 2) {
                Mode = 3;
                if (Mode == 3) {
                Mode = 0;
        buttonState = val;                 // save the new state in our variable
      // Now do whatever the lightMode indicates
      if (Mode == 0) { // all-off
        digitalWrite(led1Pin, LOW);
        digitalWrite(led2pin, LOW);
      if (Mode == 1) {
        digitalWrite(led1Pin, HIGH);
      if (Mode == 2) {
        digitalWrite(led2pin, HIGH);
      if (Mode == 3)  {
Cheers smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thank you that was very useful
Logged
Offline Offline
Edison Member
View Profile
Quote
How about this:
led1 = (button pressed & (led1 is on))? off:on;
led2 = (led1 is on)? off:on;
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Code:
const int buttonPin = 3;    // pin to read button
const int oddLED = 9;       // LED lit on odd button presses
const int evenLED = 10;     // LED lit on even button presses
int pressCnt = 0;           // total # of button presses
  pinMode(buttonPin, INPUT);
  // if button is pressed
  if( digitalRead(buttonPin) ) {
    // increment count
    pressCnt++;
    // turn on even or odd LED
    digitalWrite(oddLED, pressCnt % 2);
    digitalWrite(evenLED, !(pressCnt % 2));
    // debounce
    delay(200);
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
@BlueEyes:
What does that code do if the switch is held down. It does not do what OP asked for.
How is the switch supposed to be wired to use that code? Posting code that works with hardware, but not describing how to connect the hardware does the newbie poster little good.
Logged
Offline Offline
Edison Member
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
View Profile
Looks like I got bored too :-)
Code:
int led1Pin = 8;
int led2pin = 9;
boolean modeChanged = false;
const int NUM_MODES = 4;
void loop(){
                Mode++;
                if (Mode >= NUM_MODES) {
                    Mode = 0;
                modeChanged = true;
    if (modeChanged) {
        switch(Mode) {
        case 0:
        case 1:
        case 2:
        case 3:
(warning: compiled but untested code, use at your own risk ;P )
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
@PaulS:
The OP said
Quote
and that's what the code does.  If the OP wants to handle the case where someone holds the button down then they could replace the "if" statement with a "while" statement.
I thought that the code was documented enough to show how it was wired, but I'll explain how I set it up on a breadboard.  A momentary button was connected on one side to 5V and the other to ground through a 10K pull-down resistor and to Arduino digital pin 3 ("buttonPin") through a 100 Ohm resistor.  Two LEDs were connected to ground via 330 Ohm resistors and their anodes were connected to Arduino digital pins 9 and 10 ("oddLED" and "evenLED").
When the sketch runs neither LED is lit.  When the button is clicked the LED connected to Arduino digital pin 9 ("oddLED") lights.  When the button is clicked again the lit LED turns off and the LED connected to Arduino digital pin 10 ("evenLED") lights.
« Last Edit: October 01, 2012, 09:53:27 am by Blue Eyes » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No, it doesn't. It changes the pressCnt variable more than once if the switch is held down. The value will be incremented every 200 milliseconds (plus a little bit) for as long as the switch is held down.
OP was looking for something that incremented the value only once each time the switch was pressed. That requires keeping track of the previous state of the pin, so that the transitions can be detected.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Well, YOU'RE defining a button press as someone holding the button down.  I'M defining a button press as someone pressing the button and then letting it up, holding it down counts as multiple button presses.  I guess it's up to the OP to define what a button press is.  What's wrong with that?  It's example code, the OP can handle extreme cases anyway they want.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Assuming that they release it withing 200 milliseconds.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Good Morning,
I was assuming a button press just that.  Pressed and then let up.  Is there a way to make it so that if the button is help down for an unspecified amount of time and then let up, it only counts as one button press?
Thank you for all of your assistance with this.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The pin state will read one way while the switch is pressed, and the other way when it is released.
By keeping track of the state from the last iteration of loop, you can tell when the transitions (to pressed or to released) occur. When you have detected a transition, the current state of the switch (pressed or released) defines which transition occurred.
Logged
Pages: [1]   Go Up
Print
Jump to:
