Loading...
Pages: [1]   Go Down
Author Topic: What can't you do with PWM compared to DAC  (Read 597 times)
Offline Offline
Newbie
View Profile
Hi.
I am learning Arduino. I have read the analogWrite actually uses a digital signal, via the PWM technique.
I also read that is good enough for dimming LED's, controlling motors, generating audio...a lot of things, after all.
My question is, what are the main things you can't achieve with PWM, but you definitely need DAC instead? I am asking in general, but also particularly in the Arduino/microcontrollers arena.
Thanks,
Dan
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
With PWM, you have an oscillating signal that you filter with a low pass filter to smooth into a ripply level.
With a DAC, you are basically writing the level you want and it stays there until you write again.
You can have dual and quad DACs with higher resolution than the 8 bits offered with PWM, easily accessed with fast I2C or even faster SPI commands.
Its also possible to create more complex waveforms if desired, such as playback of sampled files from memory.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Very interesting, CrossRoads - thanks a lot.
Is the "low pass filter" you were talking about integrated into the microcontroller or is it something I should take care of?
Dan
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
low pass filter is external, just a resistor/capacitor.
there are lots of calculator websites, for example
http://www.electronics-tutorials.ws/filter/filter_2.html
PWM switches ~490 Hz, so pick values to filter out frequencies above that.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
In general? Not much.
In Arduino terms? Quite a lot. Arduino has quite a limited PWM frequency/resolution. eg. You can't do high quality audio output.
Logged
Offline Offline
Edison Member
View Profile
Quote
To generate low frequency analog output; to generate fine analog output; to generate fast analog output; etc.
Logged
Offline Offline
Edison Member
View Profile
The flip of the coin is also true: there are cases where pwm is much preferred over dac.
Both are very application specific.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Well I pose a question to your. If one wires a PWM signal to a digital voltmeter what would it read at 50% output? If you have a DAC that outputs 0-+5vdc what will the same voltmeter display with a 50% signal?
There lies the difference and should point to applications best suited for one or the other.
Lefty
« Last Edit: November 16, 2012, 12:59:56 pm by retrolefty » Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Quote
I guess all those "1-bit-DAC" CD players are a figment of my imagination....
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
From wikipedia:
"A Bitstream or 1-bit DAC is a consumer electronics marketing term describing an oversampling digital-to-analog converter (DAC) with an actual 1-bit DAC (that is, a simple "on/off" switch) in a delta-sigma loop operating at multiples of the sampling frequency. The combination is equivalent to a DAC with a larger number of bits (usually 16-20). The advantages of this type of converter are high linearity combined with low cost, owed to the fact that most of the processing takes place in the digital domain and requirements for the analog anti-aliasing filter after the output can be relaxed. For these reasons, this design is very popular in digital consumer electronics (CD/DVD players, set-top boxes and the like)."
So not sure what you are trying to point out fungus.
Found another good description here
http://electronics.howstuffworks.com/question620.htm
« Last Edit: November 16, 2012, 01:22:54 pm by CrossRoads » Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
1-bit-DAC is an example of using PWM to generate analog signals in consumer electronics.
It does all that stuff he claims can't be done ("low frequency analog output; fine analog output; fast analog output; etc").
It may not be practical for all applications but in theory PWM+filter can do anything an DAC can do.
Logged
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
Damn, how does TI get away with selling their expensive DACs then? smiley
http://www.ti.com/docs/prod/folders/print/dac5670.html
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Gotta take the guy mentality for that one:
more bits/seconds
more power
more balls!
Gues it helps to have a higher power uP also to send it data that fast.
Features
14-Bit Resolution
2.4-GSPS Maximum Update Rate Digital to Analog Converter
Power Dissipation: 2 W
252-Ball GDJ Package
APPLICATIONS
Satellite Communications
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
When I say "in theory" it means there's practical limits...
eg. 1.2Gsps output with 14-bit resolution would need a 20 terahertz PWM clock  smiley-cool
Logged
Samplefinger
Offline Offline
God Member
View Profile
Guess it helps to have a higher power uP also to send it data that fast.
I think we would be well into (multiple?) CPLD/FPGA territory on that DAC.   Certainly a (relatively) slow but smart uP to direct all the action of the heavy equipment.
« Last Edit: November 16, 2012, 03:19:42 pm by JoeN » Logged
Pages: [1]   Go Up
Print
Jump to:
