Topic: How do I change the speed of fading with Tlc5940? (Read 932 times) previous topic - next topic
kraken667
Oct 10, 2012, 08:03 pm Last Edit: Oct 10, 2012, 08:06 pm by kraken667 Reason: 1
Hey, fresh meat here! I´ve just recently discovered Arduino and could use some help. I´m going to have 32 LEDs fading with seperate speeds in a organic way. I´ve been using example codes for some hours now, but the fading is way too rapid. I don´t know how to make a single LED to fade slow and smooth. Can you help me?
Below is the code I´m using right now, testing one LED. How do make the fading slower here?
Code: [Select]
#include "Tlc5940.h"
#include "tlc_fades.h"
TLC_CHANNEL_TYPE channel;
 Tlc.init();
 if (tlc_fadeBufferSize < TLC_FADE_BUFFER_LENGTH - 2) {
   if (!tlc_isFading(1)){
     uint16_t duration = 3000 - (analogRead(0) * 2);
     int maxValue = 4000;
     uint32_t startMillis = millis();
     uint32_t endMillis = startMillis + duration;
     tlc_addFade(1, 0, maxValue, startMillis, endMillis);
     tlc_addFade(1, maxValue, 0, endMillis, endMillis + duration);
   if (channel++ == NUM_TLCS * 16) {
     channel = 0;
 tlc_updateFades();
johnwasser
I'd think that you could change the speed of fading by changing 'duration'.  Currently it is set by an analog input on A0:
Code: [Select]
That will get you between 954 milliseconds (about a second) and 3000 milliseconds (three seconds).
You can make the decay time a constant:
Code: [Select]
      unsigned long duration = 10000; // Decay over 10 seconds
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
kraken667
Thank you johnwasser! Great...
Now, if I don´t want a total fade out, so that the LEDs never go down to zero, how do I make that happend?
johnwasser
I'd guess that you'd set the start or end point of the fade to something other than zero.
kraken667
Thanks again! Sorry for being such a neebie...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
