Loading...
Pages: [1]   Go Down
Author Topic: Use a 5v relay to trip a 12v relay?  (Read 442 times)
Offline Offline
Newbie
View Profile
What I thought would be a quick trip to Radioshack turned into three trips and much confusion.
What I'm trying to do is use my Arduino Uno to turn on and off a 120vAC device (bedroom lamp, Christmas lights, etc).
To make a long story short, the gentleman at Radioshack did not have a 5vDC relay that would handle >1A at 120vAC and suggested I instead use a 5vDC 1A at 120vAC relay to trip a 12vDC 10A at 120vAC relay. Made sense at the time.
So right now I have:
    5vDC relay, rated 1A at 120vAC (SPDT)
    12v relay, rated 10A at 110/120vAC (DPDT)
I bought a 10ft extension cord from Walmart that I cut in half; I want to wire the relays in the middle. So my question is: how do I wire these things up? Where am I getting the 12vDC to trip the second relay? Here's a picture of the two relays and their packaging: http://i.imgur.com/hnqAb.jpg
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Well, 2 problems - the 5V relay looks to have a 50, 56 ohm resistance? Arduino can't drive that. Need a transistor to drive that.
2nd, yeah you need a 12V source.
If you had 12V and the transistor, you wouldn't need the 5V relay.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Edison Member
Now, More Than Ever
View Profile
275-0217  That's not a "12V relay".  It's a relay with a 120vac coil (!), so that's not happening in our Arduino context.
[ http://www.radioshack.com/product/index.jsp?productId=2049721 ]
Return it.
Exchange it for a transistor or two - http://www.radioshack.com/product/index.jsp?productId=2062609
and get some resistors, too, 1Kohm (1/4W, 1/2W, whichever).
PS,
Add a couple of 1N4001 (or 1N400x whatever they have) diodes to that list.
« Last Edit: October 27, 2012, 07:44:38 pm by Runaway Pancake » Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Pages: [1]   Go Up
Print
Jump to:
