Loading...
Pages: [1]   Go Down
Author Topic: Eagle CAD can't route MAX3221 SSOP chip  (Read 1528 times)
Kansas
Offline Offline
Newbie
View Profile
I'm having a heck of a time using a MAX3221 with my design. Eagle refuses to route anything to it. I assume it's a signal path size issue and Eagle thinks the connections will be too large for the pins but changing various design rules doesn't seem to help me.
I'm hoping someone has some suggestions.
Thanks
« Last Edit: October 08, 2012, 01:30:18 pm by mancow » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Where'd the symbol come from?
Post the library, let's see what you're working with.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Kansas
Offline Offline
Newbie
View Profile
S-232 Transceivers with AutoShutdown
1µA Supply-Current, True +3V to +5.5V
http://dbserv.maxim-ic.com/
Package: SSOP16
Shrink Small Outline Package
package type SS
https://dl.dropbox.com/u/5509596/maxim.lbr
Logged
Kansas
Offline Offline
Newbie
View Profile
I got it. I had to change the routing grid from 50 to 10.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Yeah, learn that one the hard way.  I usually set it down even lower, like 2mil.
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 That is one of the few things that angers me with Eagle. I have not figured out how to save the grid to a preference. Every time I bring the program up I have to remember to set the grid.
 Great program otherwise.
Logged
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
You can create a Grid alias.  Basically set the grid the way you want it.  Then right-click on the Grid icon (it's at the very top, right under the Open one), select New and give it a name.  Now regardless of what you're doing, regardless of what the current grid is, you can right-click on the grid icon and select the one you created.  Voila.  You can do this both for the board and schematic views.
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
 That was easy! Does the grid name and setting follow the project or does it set the grid the same way every time you open Eagle?
Logged
Colorado
Offline Offline
Edison Member
View Profile
It's saved with the program settings.  Next time you open Eagle, just right click on the Grid button and select your default before you start doing anything.  I have a few different settings this way for different purposes.
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
 Thanks KirAsh4!
Logged
Pages: [1]   Go Up
Print
Jump to:
