Topic: temperature sensors (Read 951 times) previous topic - next topic
pittom
Hi,i did not play with arduino for a while and now trying to do temperature sensor with  OneWire but every example does not work.My plan is to have 2 or 3 temperature sensor hooked up to hot tub to keep from freezing pump,check and set/turn on heat all from phone. I have got my uno and ethernet shield to work over internet but can not find OneWire code that workes so i can learn from.
does anyone have code that works?
thanks tom
PaulS
Yes, I have some. Probably won't work with your sensors. On the other hand, it might. If you said what kind of sensors (in the form of a link), and showed your code, and explained what "it didn't work" really meant, perhaps some real help would be forthcoming.
MarkT
Which temperature sensor?  What code?  We are not mind readers.  [well perhaps on a good day!]
pittom
this is the sensor https://www.sparkfun.com/products/9438 and the arduino  library OneWire
dhenry
If you want to use OneWire on that sensor, it is probably a ggod idea that that sensor speaks OneWire.
MarkT
LM335A requires analogRead(), not OneWire.
If you really want some code for it you could look at that page and read the "Comments" section.
pittom
well thanks anyway but i tried codes from "Comments" section and when i check code it comes up error and not sure why,that is why i asked if anyone had sample code that works so i can learn from
PaulS
Show us what code you tried. Don't expect us to go looking.
Perhaps you could ask somewhere. Like, maybe, I don't know, how about here on the forum? Post the error messages.
