Topic: random integers to string arrays (Read 2744 times) previous topic - next topic
AXNRXN
Hi All,
I'm working on a project where I have to send string commands to a stepper motor controller. These commands look typically like "10030XYG" or "-1500X45000YG" and tell the control board how many steps to move the X or Y motors. I have a separate program that can take commands that I type in, load these command strings into an array, and send them out to the control board as needed. But, what I really want to to is randomly generate the X and Y positions, convert those to strings, append the X/Y/G charachters, and then load them into the array.
I'm trying to get my head around getting everything in a string format that will load into the "char* stepArray[]" string array. So, I made another test program shown here in order to get this portion to work. I'm using String objects for now, but they don't seem to agree with the char* stepArray[].  I get a "String_Tests:51: error: cannot convert 'String' to 'char*' in initialization" error line. I understand string objects are not recommended due to memory issues. But, so far, trying to get one command string out of a character array is proving difficult. I've also fooled around with using "ltoa" to convert the random long numbers into strings, but then I have to append the letters and so forth.
I think that if I can get my stepArray[] array to load up, I should have this issue licked. Thanks for any help and recommendations,
--> K
Test program to convert random integers into strings commands to send to Stepper Control Board.
//******************Constants***********
//******************Variables***********
String stepCommand = "";
//****************Function Prototypes******
//***************Setup******************************
  randomSeed(analogRead(0));
//*************Main Program Loop************************
long randNumber_X1 = random(-10000, 10001);
long randNumber_Y1 = random(-10000, 10001);
long randNumber_X2 = random(-10000, 10001);
long randNumber_Y2 = random(-10000, 10001);
Serial.print(randNumber_X1);
Serial.print(" ");
Serial.println(randNumber_Y1);
Serial.print(randNumber_X2);
Serial.print(" ");
Serial.println(randNumber_Y2);
String firstPosition = stepCommand + randNumber_X1 + "X" + randNumber_Y1 + "Y" + "G";
String secondPosition = stepCommand + randNumber_X2 + "X" + randNumber_Y2 + "Y" + "G";
String homePosition = "0XYG";
Serial.println(firstPosition);    //This prints to Serial Monitor as expected
Serial.println(secondPosition);  //This prints to Serial Monitor as expected
Serial.println(homePosition);  //This prints to Serial Monitor as expected
char* stepArray[] = {    //Load up CNC Patterns into string array. HOW TO LOAD STRINGS???
  firstPosition,
  secondPosition,
  homePosition
//*********************FUNCTIONS***************************
guix
#1
Oct 09, 2012, 01:31 am Last Edit: Oct 09, 2012, 01:34 am by guix Reason: 1
Edit: sorry I was wrong :smiley-zipper:
holmes4
Don't use String (the object)! use the str (char array) functions or sprint() Or DIY it, lookup (it's handed out to students as an exercise) writing your own routine to convert an int to a string. Hint lots of dividing by ten to do.
Mark
holmes4
PeterH
 firstPosition,
 secondPosition,
 homePosition
You can do it by declaring a character array long enough to hold the whole string (including the terminating null character, and then using sprintf() to write your string into that buffer.
const int LEN=20; // pick a number big enough to hold your longest command string + 1
char command[LEN];
sprintf(command, "%dX%dYG", x, y);
Although you seem to be trying to declare an array of strings, I suggest you only format and send one command string at a time - you haven't got much memory to play with.
If I were you I'd write a function which has function arguments providing the X and Y values as integer values, and sends the corresponding command string to your device.
AXNRXN
PeterH,
This method is close to working. I can get the X value to print in there, but the Y value seems to be chopped to either a 0 or -1.
Serial.print(" ");
char command[LEN];
sprintf(command, "%dX%dYG", randNumber_X1, randNumber_Y1);
Serial.println(command);
And the Serial Monitor output is below. The first line just prints the random numbers, the second is the sprintf conversion. Any clue as to whats up?
8899 -3632
8899X0YG
4295 -5583
4295X0YG
-2445 -3267
-2445X-1YG
-5280 -9285
-5280X-1YG
342 -2815
342X0YG
-5991 -3474
-5991X-1YG
guix
AXNRXN
Ah, "l" for a long integer. That made it work.
Many props,
---> Karl
PaulS
Of course, given the range of values that you are storing in the variables, it's hard to see why they are long.
