Topic: Multiple buttons with single wire input, help needed. (Read 4003 times) previous topic - next topic
smit6089
Hello everyone, I'm new to the Arduino community and have only been learning for a couple of days. I have greatly enjoyed learning and have discovered a lot from looking at these forums. However I'm stumped on my latest endeavor.
I've managed to get each button to control a separate LED through a single analog wire. The problem is I can not figure out for the life of me how to not continue to repeat the effect. For instance, when I press button one, led one increases in brightness. If I hold down button one, led one continues to cycle through it's brightness level.
In short I just want a held button to act as a single button action and not continually repeat. One press, one action, until it is released and pressed again. I've tried several ways of doing this to no avail so I'll share my raw setup up and code. If you can help that would be great, and feel free to be honest if I've just done something completely backwards. I may be a noob but I can take some criticism. Thanks in advance.
And of course, if you want to use this code and/or setup feel free, just please share your uses/discoveries.  :)
Here's the setup:
And here is my code:
Code: [Select]
Desired effects:
LED ONE, when button is pressed increase one level in brightness untill button is released, and pressed again, then increase in brightness again
LED TWO, only light whil button two is pressed and held.
LED THREE and FOUR, Light when button is pressed. Turn off when button is pressed for a second time
const int switcharrayPin=0; //switch array to analog pin 0
const int ledonePin=11; // LED ONE
const int ledtwoPin=10; // LED TWO
const int ledthreePin=9; // LED THREE
const int ledfourPin=6; // LED FOUR
int ledonelevel=0; // Set ledone begining level
boolean switchone = false; // Hold value of Switch ONE
boolean switchtwo= false; // Hold value of Switch TWO
boolean switchthree= false; // Hold value of Switch THREE
boolean switchfour = false; // Hold value of Switch FOUR
  Serial.begin(9600); // Start serial communication
  pinMode (switcharrayPin, INPUT); // set switch array to input
  pinMode (ledonePin, OUTPUT); // set ledone to output
  pinMode (ledtwoPin, OUTPUT); // set ledtwo to output
  pinMode (ledthreePin, OUTPUT); // set ledthree to output
  pinMode (ledfourPin, OUTPUT); // set ledfour to output
  int switcharrayval = analogRead(switcharrayPin); //Read switcharryPin
    if(switcharrayval > 350 && switcharrayval < 550) //Check if switch one was pressed
    ledonelevel = ledonelevel + 51; // Add 51 to ledonelevel
    if (ledonelevel >255) ledonelevel=0; //Recycle LED after max level
    analogWrite(ledonePin, ledonelevel); // Cycle led through level
  if(switcharrayval > 260 && switcharrayval < 350) // Check if switch two was pressed
    switchtwo=true; // Turn on switch two
  if (switcharrayval < 260 || switcharrayval > 350) // Check if switch two was released
    switchtwo=false; // Turn off switch two
  digitalWrite(ledtwoPin, switchtwo); // Set ledtwo to switch two
    if(switcharrayval > 230 && switcharrayval < 300) // Check if switch three is pressed
    delay(10);
    switchthree=!switchthree; // If so reverse the value of switch three
    digitalWrite(ledthreePin, switchthree); // Set ledthree ledthree to same value as switch three
  if(switcharrayval > 150 && switcharrayval < 225) // Check if switch four is pressed
    switchfour=!switchfour; // If so reverse the value of switch four
    digitalWrite(ledfourPin, switchfour); // Set ledfour to same value as switch four
  Serial.println(analogRead(switcharrayPin)); // Display switcharrayPin value in serial monitor
  delay(100); // Set serial monitor delay
Grumpy_Mike
The code is a bit confusing. I would write it so that the first thing you do is to set a variable that indicates what switch is being pressed.
Then write the code that does the action you want.
You will need a variable that notes the time when the button was first pressed using millis(), so you will need another that notes what switch was pressed the last time through the loop. I can't see any of that in your code and you need that sort of information if you want to do what you say.
smit6089
Thanks for the reply!
I know the code I provided won't give the desired result, it was just more or less the foundation that I'm building off of.
I've been fighting with this all night and finally stripped it down to a single led, coded it as if it was a digital switch just provding high or low, and not an analog. Then I just went back and added my if() statements. Finally it works! Now I'd just need to add separate booleans for each of my four LEDS but I might actually be able to handle that.  :P
If anyone is interested here is the working code:
Code: [Select]
Desired Effects:
Led One, When button one is pressed, LED one is On.
Do not change state untill button is released and pressed again.
// Define Constants
const int switcharrayPin=A0; // Set switch array pin to analog pin 0
const int ledonePin=11; // Set LED pin to 11
// Define Variables
boolean switchonecurrent=false; // Boolean to hold current switch position
boolean switchonelast=false; // Boolean to hold last switch position
long int switcharrayvalue=0; // Keep track of the switch value between 0 and 1280
  pinMode (switcharrayPin, INPUT); //set switch array pin to an input
  pinMode (ledonePin, OUTPUT); // set switch array pin to an output
  switcharrayvalue=analogRead(switcharrayPin); // Read Switch Array
  if(switcharrayvalue > 350 && switcharrayvalue < 550 && switchonelast==false)// See if switch one is pressed when it was not pressed before
    switchonecurrent = !switchonecurrent; // If so, flip switch ones value
    switchonelast=true; // If so, make switch ones last state to true
    if(switcharrayvalue < 350 || switcharrayvalue > 550)// See if button one is not pressed
      switchonelast=false; // If it's not, set switch ones last state to false
  digitalWrite(ledonePin,switchonecurrent); // Write switch ones current state to LED One
smit6089
Well I'm back to bother you guys some more.
I manged to get all four switches controlling their own LED, push on, push off, held buttons ignored. So I'm excited about that. However I still have the obvious issue of the switches bouncing. I've debounced single switches using delay() but I've been told this is bad practice. On top of that I don't really see that being feasible with this switch array. Also with it all being through one analog pin I don't see a hardware solution. I know to you guys this is probably a simple problem but I feel that if I don't really learn and understand these basics I'm just shooting myself in the foot before I learn to walk.
Here is my current code, any comments are always welcome, and of course examples. Thanks so much!
Code: [Select]
// Define Constants
const int ledtwoPin=10; // Set LED two pin to 10
const int ledthreePin=9;// Set LED three to pin 9
const int ledfourPin=6; // Set LED four to pin 6
// Define Variables
boolean switchonecurrent=0; // Boolean to hold current switch one position
boolean switchonelast=0; // Boolean to hold last switch one position
boolean switchtwocurrent=0; //Hold switch twos position
boolean switchtwolast=0; //Track switch twos position
boolean switchthreecurrent=0; //hold switch threes position
boolean switchthreelast=0; //track switch threes position
boolean switchfourcurrent=0; //hold switch fours position
boolean switchfourlast=0; //track switch threes position
  pinMode (ledonePin, OUTPUT); // set LED one pin to output
  pinMode (ledtwoPin, OUTPUT); // set LED two pin to output
  pinMode (ledthreePin, OUTPUT); //set LED three pin to output
  pinMode (ledfourPin, OUTPUT); //set LED four pin to output
  // LED ONE CHECK AND SWITCH CODE
    //  LED TWO CHECK AND SWITCH CODE
  if(switcharrayvalue > 320 && switcharrayvalue < 350 && switchtwolast==false)// See if switch two is pressed when it was not pressed before
    switchtwocurrent = !switchtwocurrent; // If so, flip switch twos value
    switchtwolast=true; // If so, make switch twos last state to true
    if(switcharrayvalue < 320 || switcharrayvalue > 350)// See if button two is not pressed
      switchtwolast=false; // If it's not, set switch twos last state to false
  digitalWrite(ledtwoPin,switchtwocurrent); // Write switch twos current state to LED two
  //  LED THREE SWITCH AND CODE
  if(switcharrayvalue > 240 && switcharrayvalue < 260 && switchthreelast==false)// See if switch three is pressed when it was not pressed before
    switchthreecurrent = !switchthreecurrent; // If so, flip switch threes value
    switchthreelast=true; // If so, make switch threes last state to true
    if(switcharrayvalue < 240 || switcharrayvalue > 260)// See if button three is not pressed
      switchthreelast=false; // If it's not, set switch threes last state to false
  digitalWrite(ledthreePin,switchthreecurrent); // Write switch threes current state to LED three
  //  LED FOUR CHECK AND SWITCH CODE
  if(switcharrayvalue > 190 && switcharrayvalue < 220 && switchfourlast==false)// See if switch four is pressed when it was not pressed before
    switchfourcurrent = !switchfourcurrent; // If so, flip switch fours value
    switchfourlast=true; // If so, make switch fours last state to true
    if(switcharrayvalue < 190 || switcharrayvalue > 220)// See if button four is not pressed
      switchfourlast=false; // If it's not, set switch fours last state to false
  digitalWrite(ledfourPin,switchfourcurrent); // Write switch fours current state to LED four
Grumpy_Mike
Look at the blink without delay example, that is the basis of what you want to do.
You get the time now with millis and compair the time now whit the time you want certain actions to finish or change.
Also look up the concept of a state machine it is what you want to implement.
