Loading...
Pages: [1]   Go Down
Author Topic: What is the part I'm looking for called?  (Read 620 times)
Offline Offline
Full Member
View Profile
I need some sort of chip that can be used to switch an 8 bit data bus between two outputs and I have no idea what it's called. I don't really know how to describe it other than 8 electronically operated SPDT switches in a chip so I drew a picture
where HIGH on 's' switches 'a1' to 'o1H' and LOW on 's' switches 'a1' to 'o1L'
I need there to be 8 of these in one chip with separate inputs 'a' and outputs 'o' for each, but the selection 's' for the switch needs to be common to all of the 8 switches so that I can switch the whole bus at once. The switches don't have to be bidirectional, but bonus points if they are. Needs to be 5v logic.
Logged
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
this sort of thing... http://uk.rs-online.com/web/p/multiplexer-switch-ics/6711239/
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Norfolk UK
Offline Offline
Edison Member
View Profile
Or this http://www.ti.com/lit/ds/symlink/sn74ahc157.pdf though they only come in nibble size not byte so you would need 2 per bus.
Logged
Offline Offline
Full Member
View Profile
I've seen plenty of 4 bit ones and I suppose they would work although I'd rather use an 8 bit version. The FSHDMI04 could work although it's $3 on digikey (while 4 bit versions are 50 cents) and has ~20 repetitive/unused pins. It's kinda strange really, digikey has tons of single 4 bit switches and tons of dual 8 bit switches but they don't have any single 8 bit switches. Or maybe they're labeled wrong. The FSHDMI04 was labeled as a 3 x 2:1 instead of an 8 x 2:1.
I'm also looking for a 16 bit binary counter on digikey and can't find one. All the ones I've seen have 2-8 of the least significant outputs missing which sort of seems to defeat the purpose. I've settled for the CD4040BE for now.
« Last Edit: October 09, 2012, 03:30:26 am by bobthebanana » Logged
Offline Offline
Sr. Member
View Profile
Do you want a chip that has 8 inputs, 8 outputs and "transfers" (and latches) the 8 input states to the outputs when a pin is toggled?
If so, it sounds like you want a simple octal latch: http://www.nxp.com/documents/data_sheet/74HC_HCT573.pdf
They show two part numbers... the '573 version just has convenient pin placement (all inputs on one side and all outputs on the other).
It's 5 volt logic as well.....
Hope this helps.
« Last Edit: October 09, 2012, 11:25:07 am by krupski » Logged
Offline Offline
Sr. Member
View Profile
He wants a chip that switches 2 8 bit busses to 1 8 bit buss, He could do it with *two* latches if they have high Z outputs.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Just need the equivalent of two 74LS244, enable 1 or the other to drive the bus, or 74LS245 if need a transceiver.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Full Member
View Profile
KeithRB is correct in understanding what I need. I realize that there are many ways to accomplish this task using two latches, two 4 bit 2:1 demultiplexers, etc. but I would like it to be contained in one chip. If there is a chip which is the equivalent of two 74LS244 with common inputs but seperate outputs please let me know. Or if anyone can find an 8x2:1 demux on digikey that would be great as well.
Logged
Offline Offline
Sr. Member
View Profile
You could use a picAxe 40x2 to do it, depending on how fast you wanted it to switch.
$11.00 from sparkfun
(Of course, you could use the ATMega2560)
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
The parts are apparantly called "bus switch" these days at ti.com. I don't see any 2:1 parts . Use two parts such as
http://www.ti.com/lit/ds/symlink/sn74cbt3345.pdf
to connect each to the common bus.
Logged
Offline Offline
Full Member
View Profile
Yea that seems to be the only alternative, problem is your layout ends up looking something like this:
It would be much nicer if they stuck two of these in one chip and tied the inputs together. It's quite surprising that they don't exist. I'll keep searching though.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Two in one - now you're talking a big 24 pin+power pins+control pins chip. All the signals have to come to that area also.
And that only handles 2 buses.
If you have more than 2, seperate parts make way more sense.
If you're designing for 4 layer, 8 layer, 16 layer cards, there is way more flexibility in routing too. Parts can be spread out more for routing to more connectors.
A simplifed 1 layer routing doesn't really reflect much.
Logged
Offline Offline
Full Member
View Profile
I suppose you're right. While this was originally intended to be nothing more than a simple, homebrew, single sided pcb, I just re-routed it with 2 layers(the most I can do at home) and it's certainly simpler; I can expand to an infinite number of chips easily. I'll probably be switching to 6 or more output busses so this is actually ideal.
Logged
Offline Offline
Sr. Member
View Profile
What about a programmable logic array like an Atmel PLD?
I use an ATF16V8B as an address decoder for a Motorola 68HC11 board - works like a charm. You would need a bigger part though (8 inputs, 16 outputs).
You can write the logic code for it with (free) WinCUPL from Atmel, then burn the JEDEC file to it with an eprom programmer. It's flash, so you can reprogram it.
OR..... this may sound crazy... if you can tolerate slow 100-ish nsec. propagation delay, use a 16 bit EPROM or FLASH memory chip and just program the bit pattern you need in it.
I did that too - years ago - to make a switch type joystick to motor driver decoder (the EPROM fed the H-bridges in the proper pattern so that the platform moved the same way the joystick pointed).
Good luck.
Logged
Pages: [1]   Go Up
Print
Jump to:
