Topic: Communication between multiple ATmega328 nodes (Read 2157 times) previous topic - next topic
davivid
I have been researching various communication technologies to interconnect around 10 ATmega328 devices, I2C, SPI, DMX, RS-485.......The list goes on, and gets confusing.
I would really appreciate some real world advice as to the suitability for my project. In essence:
  • I will have 10 addressable ATmega328 nodes, that each contain a sensor, and a single RGB Led.
  • Each node will receive PWM RGB data
  • Each node will transmit sensor data - when it is activated (HIGH or LOW, usually one at a time)
  • Each node will be approx 20cm from the next
  • These will be connected to a Master device which will act as the USB Computer bridge.
As I see it there are two approaches:
1)the Master will write to each device, and continually scan through the array of devices asking for the sensor state.
2)the Master will write to each device and each device can write to the Master when its sensor is HIGH.
Which would be the best approach?
What would be the most suited communication technology to implement this?
CrossRoads
#1, less chance of two slaves responding together.
RS485 is designed for that.
Grumpy_Mike
Quote
You sure of that, it is difficult to send lots of PWM, the data to make the PWM fine but not the signal itself.
Yes go for 1, I would use DMX.
CrossRoads
Here's a couple of application notes on wiring it up
http://www.maximintegrated.com/app-notes/index.mvp/id/763
http://www.maximintegrated.com/app-notes/index.mvp/id/723
CrossRoads
DMX - bit overkill, no?
Master sends out a 6 byte message
message coming
node address
red pwm
blue pwm
green pwm
message end
node responds with current sensor status
node address
on/off
davivid
as a two wire interface?
CrossRoads
Can be two wire if only want half-duplex.
See the app notes I posted for wiring examples.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
