Topic: Using keypad to scroll. HELP PLEASE (Read 2410 times) previous topic - next topic
jacobblue
hey i'm using a 16x2 LCD and 3x4 matrix keypad. I've programmed an external button to be pressed if i wanted to scroll through pages in my LCD. But is there a way that i can program, where i can use my keypad keys such as "#" or "*" to scroll through my pages? i tried several ways to use them but i can't. Any help would be greatly appreciated:) thanks in advance
 currentButton = debounce(lastButton);
 if (lastButton == LOW && currentButton == HIGH)
   ds += 1;
 if (ds >= 4){
   ds=1;
 if (ds == 1){
   //write the stuffs required for page 1
   lcd.setCursor(0,0);
   lcd.print("HOME PAGE        ");
   lcd.setCursor(0,1);
   lcd.print("T/I= ");
   lcd.setCursor(6,1);
   lcd.print("NOT=  ");
   lcd.noBlink();
 if (ds == 2){
   //write the stuffs required for page 2
   lcd.setCursor(0,0);
   lcd.print(" Set Interval:   ");
   lcd.setCursor(0,1);
   lcd.print("           ");
   lcd.setCursor(0,1);
   lcd.blink();
 if (ds == 3){
   //write the stuffs required for page 3
   lcd.setCursor(0,0);
   lcd.print("Set No.of Times:");
   lcd.setCursor(0,1);
   lcd.print("          ");
   lcd.setCursor(0,1);
   lcd.blink();
 lastButton = currentButton;
PaulS
Snippets are us is down the road a ways. Here, we need to see all the code.
So you posted a snippet of code that has nothing to do with an attempt to use the * and # keys on the keypad. Why?
Using Tools + Auto Format before posting code (at least you did that properly) would be a good idea. As would consistent placement of curly braces. I prefer the "on a line by themselves" placement, myself. Others don't.
When there are mutually exclusive blocks of code, if/else if/else works better than if/if/if
jacobblue
That code is the one i used when i used an external button.
key = keypad.getKey();
  if (key == '*' )
      ds+=1;
    if (ds >=4)
      ds=1;
    if(ds ==1){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("T/I= ");
    lcd.setCursor(6,1);
    lcd.print("NOT=  ");
    lcd.noBlink();
  if (ds == 2){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("           ");
    lcd.setCursor(0,1);
    lcd.blink();
  if (ds == 3){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("          ");
    lcd.setCursor(0,1);
    lcd.blink();
this is the one i used to try the key '*'
but it just runs one cycle only, i can't scroll multiple times.
PaulS
What does multiple mean? How would the Arduino know when to quit scrolling? What does "scroll" mean, exactly?
It looks like each time you press a key, you want to change what is displayed on the LCD. I don't understand how that relates to scrolling.
jacobblue
yeah I meant the LCD displaying different things, each time i press. But how do i do that with a '*' key rather than an external button?
PaulS
You want the value of ds to increment by 1 each time you press the '*' key?
It looks like it is doing that now. Though, to be honest, the extra braces and poor indenting are making it hard to tell.
      ds+=1;
No braces needed.
Use Tools + Auto Format to fix the indenting.
Also, adjusting the value of ds and using ds are completely unrelated activities. Putting the code to use ds inside the block that detects a keypress and decides that it is a '*' is wrong.
jacobblue
oh sorry about the number of 'if's and brackets  used, i myself got confused sometimes. thank you for the help, i will try it tomorrow and let you know.
so are there any better ways to program this?
