Topic: 16 Channels of 15V Analog Inputs... Any Suggestions? (Read 6153 times) previous topic - next topic
lxmyers
Hi All,
       I'm trying to finish off a project I started a while ago but I've been having a bit of trouble with the Analog Inputs...
What I'm trying to do...
I need to be able to read the voltage of 16 individual inputs with a reasonable level of precision (12bit, maybe?). Input voltages could be anything between 5VDC and 15VDC.
Can anyone provide any suggestions on a way to do something like this?
Any help would be greatly appreciated.
Thanks Guys,
Alex
KeithRB
Is 10 bits (1024 steps) not enough? 12 bits places a lot more effort on you rpart to get everything just right.
IF 10 bits is enough than some of these:
https://www.sparkfun.com/products/8636
Along with your analog inputs should work.
You can also google 12 bit ADC SPI
KeithRB
I also found this:
http://www.linear.com/product/LTC2308
MarkT
That's not 15V compatible.
That's the big issue.   But we need more info about signal source before choosing an appropriate method of handling the signals - high impedance?  low impedance?  Definitely within the 0..15V range?
Clearly an analog multiplexer good for 15V would be a start (the original CMOS 4000 series can do that I think).  But converting down to 5V needs either an active or passive attenuator circuit.  And up-converting the signals to drive the analog multiplexer might be needed.  I feel there is probably a modern 16way analog multiplexer that can handle 15V analog and use 5V digital - might be surface-mount though.
KeithRB
That is why they have a thing called a voltage divider.
CrossRoads
DG408 into resistor divider into MCP3201.
Or signals into voltage dividers into MCP3208
www.maxim-ic.com for DG406
www.microchip.com for MCP320x
Far-seeker
That's possible of course, but precision is potentially going to take a big hit even before the resolution of the ADC is factored in.  From the perspective of the signal's information content a voltage divider going from 5 to 15 V down to 0 to 5 V means there will be roughly three times less usable information detectable in the output signal.  For some applications that's not a problem, for others it will be.  Instead, I would check to see if there is an affordable ADC chip/module that can handle the orignal input voltage and output serial communication of some sort at 5 VDC.
KeithRB
Assuming that you are not in the noise, which you shouldn't be if you choose the divider correctly, 4196 steps at 5 V gives you the same resolution as 4196 steps at 15 volts, you are not losing anything.
Docedison
Quote
and to solve the Granularity issues a variable Vref (DAC) might be used to solve this:
Quote
voltage divider going from 5 to 15 V down to 0 to 5 V means there will be roughly three times less  1/3 less usable information detectable in the output signal
so change the Vref as required to increase the effective available information by providing a Vref suitable to the measurements.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
retrolefty
I suspect you will have a very hard time trying to find, if any indeed exist, any ADC chips that allow input signal voltages to be higher then it's Vcc voltage (or lower then Vdd), which in most cases I'm aware of is limited to standard Vcc values of 5 vdc or lower. And any ADC type module that can handle that high of input voltages would just be using some kind of programmable front end attenuator (voltage divider) and still process the ADC conversion at standard Vcc values.
Lefty
fungus
Hi All,
Thanks Guys,
Alex
There's bound to be an I2C device for this. Google for "I2C DAC" or something like that.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
CrossRoads
Most ADCs seem to be limited to +/-10V signals.
For instance, this Anaog Devices part
http://www.analog.com/static/imported-files/data_sheets/AD7656_7657_7658.pdf
uses +/-15V supply, Performs 6 simultaneus conversions, and looks to have good performance #s.
So take the +/-15 input, get some trimmed resistors to divide it down by 1/3, and off you go.
They have a good parametric search feature so you can find a part that meets your needs.
Far-seeker
I was refering to usable information, so noise is a potential factor unless everything is in a Faraday cage.  No matter how well chosen the divider configuration is it can't prevent EMF induced noise as it travels from the output of the divider to either an analog pin on the Arduino board or a separate ADC chip.  Divide 4196 steps into 5 V and then into 15 V, that will give you what the respective difference if voltage is between each step for each voltage level.  15 V is simply going to be more tolerant, as in a given level of noise is going to impact the ultimate digital signal level less than at 5 V.
Obviously, a voltage divider right next to an Arduino's/ADC's input pin will be better in either cases than one that has to go an inch or more through a wire or trace.  If there are chips with voltage dividers on the same piece of silicon as the ADC that would be the closest to ideal as possible.  That's why I suggesting looking to see if such a thing was available (if I knew such a thing existed I would have linked to an example).  Depending upon the application it might not be necessary, but IMHO it's worth a little time to investigate the possibility.
Quote
Thanks for the correction, I was conflating a couple of different ideas in my head while typing... :smiley-red:
As for the VRef, in a Arduino it can be anything on a range of 0 to 5 VDC and the default for most Arduinos will be 5 VDC.  Unless you are refering to doing the ADC outside of the Arduino with the signal at a higher voltage level, I'm not sure what changing VRef on the Arduino would improve.
As mentioned before I didn't know of any off-hand.  If they do exist they would be potentially better, even if they used chip-level voltage dividers to step-down to 5 V or some other VCC level, than implementing a voltage divider by either through-hole or surface-mount resistors for reasons I also mentioned above.  An exhaustive search is probably not warrented, but in my mind perhaps 15 to 30 minutes of Googling would be justifible.
Edit: Looks like CrossRoads found something similar while I was typing.
Docedison
AS to voltage dividers has anyone considered that an op-amp can have less than unity gain, that they make great attenuators as well and handle +/- 15 Vin as well? at ANY input impedance? 10 ohms to a T ohm are readily possible.
Bob
--> WA7EMS <--
CrossRoads
Op amps can add some noise to the signal tho. Resistors not so much.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
