Topic: Max7219 and 8x8LED matrix - all LEDs are constantly on (Read 8093 times) previous topic - next topic
CrossRoads
Perhaps - do you have a part number? Just about anything can be found on the internet.
This is what mine looks like.  CSM-8826 is on the artwork it the back. Side is marked A5880SRSG-A, which seems incorrect - other A5880 parts I could find are only 16 pin parts.
I think I need to re-do my fonts to turn them 90 degrees for this part.
And do a little experimenting, see where "upper left" vs "lower right" is so the fonts make sense.
I defined an 8x32 array to represent the display, not sure I have that lined up with my chip callouts from left to right either.
So for example if I call 0,0 the lower left, 7,0 the upper left and 0, 31 the lower right and 7,31 the upper right, I'm not sure I'm send stuff there now.
Maybe I should flip it 31,7 for upper left and 0,0 for lower right - probably easier to visualize and keep straight that way.
Then call 3 the left display and go across 2-1-0 to the right.
Was just glad to show the hardware all worked to start - having left off +5/Gnd to 3 chips had me stumped for a bit  :smiley-roll-sweat:
yumology
I built my own mini LED matrix. One with a common anode and one with common cathode. The common cathode works brilliantly, the common anode, well I can't get it to work at all. Attached is the schematic for what works and doesn't.
So it looks like I can get either a new set of LED matrix's or the 7221's. I can't think of a way to get this to work any other way...
bratan
Any luck with your matrix? I have same problem with driving bicolor (common anode) matrix. But someone suggested to use a diodes on SEG A- SEG G lines...
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, etc.
CrossRoads
#18
Nov 07, 2012, 09:01 pm Last Edit: Nov 07, 2012, 09:10 pm by CrossRoads Reason: 1
I didn't realize you had common anode bratan.
I was suggesting diodes for common cathode to prevent the max7219 from trying to source current into the cathode when it was put into shutdown mode.
Now that I think about it tho:
In common cathode,  cathode goes to 7219 to prevent it from driving matrix cathodes high when in shutdown
In common anode, anode goes to 7219 to prevent it from pulling matrix anode low when in shutdown
In both cases, the non-driving 7219 is isolated from the common pin so the other part can control the shared line.
I'll draw this up when I get home.
CrossRoads
Dual MAX7219 controlling common cathode two-color array
CrossRoads
And the common anode version, haven't filled it out as much but one can get the idea
Aaron_dyer
Crossroads, I just built a single 8 x 8 on a protoboard and used your code in this forum...pretty cool...displays a checker board type matrix lit up that shifts back and fourth...nice..
CrossRoads
Thanks Aaron.
If you're seeing the checkerboard, then you are running old code.
I have posted, for you, the new code that works much better.  I suggest you find that.
MichellePerez
please, i need heal i have the same problen, All the leds are always ON, but my matrix that i used, it's complite with the controller integrated.  i don't know what i have to do, please healp =(
Paul__B
I don't know what I have to do,
Start (always) by actually explaining your situation.
What do you mean by "complete with the controller integrated"?
Where did you get it?  Give us the weblink for this item.
If it is in fact one like this,
(But not from that seller), then please note that at least one vendor on eBay has been providing modules with the wrong (reverse polarity) version of the matrix resulting in the display brightly illuminating all LEDs at turn-on and merely showing faint suggestions of a pattern when correctly driven by code.
If that actually happens to be the case, you should claim a refund from the vendor.  There are ways of using the module, but generally not worth the bother.
Note however that the MAX7219 should have a (10k) pull-up on the clock line to prevent it producing a random display - including all on - when it is not under the control of the Arduino code, particularly if you are "breadboarding" it.
MichellePerez
Hello my friend thank you so much for take the time to answer me.
yes i mean that case that you say.
the matrix resulting in the display  brightly illuminating all LEDs, even if i use lc.clearDisplay(0);  don't happen anything.  =(
im so sad for this issue, because i bought 6 matrix.
im from mexico sorry my english is not good, i bought the kit in this web site:
http://articulo.mercadolibre.com.mx/MLM-525971779-kit-de-matriz-de-led-8x8-armado-arduino-pic-avr-_JM#redirectedFromParent
i don't know if this is enough to check my problem and try to contact the provider?
ayazsu30
SOLVED. Crossroads was right, I had my annodes and cathodes connected incorrectly. Thank you!
i have the same problem and i cannot understand how to resolve..please help
CrossRoads
#27
Mar 21, 2017, 06:28 pm Last Edit: Mar 21, 2017, 06:43 pm by CrossRoads
Your anodes & cathodes are connected incorrectly? Change your wiring to reverse the connections.
Either at the matrix, or at the MAX7219.
For example, it took me 3 tries to get this wired up correctly.
https://www.youtube.com/watch?v=hwYqgyMc5S4
The first time, I thought I had the correct data sheet, not realizing I had dual-color displays and not single color so I had the first one done and realized there were 8 pins left to wire up still. Didn't even dawn on me that the matrix should have just had 16 pins and not 24 when I was putting sockets in place.
Took the 16 wires off and tried again.
This time I had the part installed 90 degrees off when I sent data, so when I sent a byte of data to the MAX7219 the byte that held the 0,0 bit location was not at the correct corner for the left to right shifting I wanted to implement (was going up & down instead), so one more time to get the bytes and the LED locations lined up vs a lot of software fooling around.
