Pages: 1 [2]   Go Down
Author Topic: Max7219 and 8x8LED matrix - all LEDs are constantly on  (Read 1671 times)
Boston area, metrowest
Perhaps - do you have a part number? Just about anything can be found on the internet.
This is what mine looks like.  CSM-8826 is on the artwork it the back. Side is marked A5880SRSG-A, which seems incorrect - other A5880 parts I could find are only 16 pin parts.
I think I need to re-do my fonts to turn them 90 degrees for this part.
And do a little experimenting, see where "upper left" vs "lower right" is so the fonts make sense.
I defined an 8x32 array to represent the display, not sure I have that lined up with my chip callouts from left to right either.
So for example if I call 0,0 the lower left, 7,0 the upper left and 0, 31 the lower right and 7,31 the upper right, I'm not sure I'm send stuff there now.
Maybe I should flip it 31,7 for upper left and 0,0 for lower right - probably easier to visualize and keep straight that way.
Then call 3 the left display and go across 2-1-0 to the right.
Was just glad to show the hardware all worked to start - having left off +5/Gnd to 3 chips had me stumped for a bit  smiley-roll-sweat
I built my own mini LED matrix. One with a common anode and one with common cathode. The common cathode works brilliantly, the common anode, well I can't get it to work at all. Attached is the schematic for what works and doesn't.
So it looks like I can get either a new set of LED matrix's or the 7221's. I can't think of a way to get this to work any other way...
New York
xronosclock.com
Any luck with your matrix? I have same problem with driving bicolor (common anode) matrix. But someone suggested to use a diodes on SEG A- SEG G lines...
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, and purchasing info smiley
I didn't realize you had common anode bratan.
I was suggesting diodes for common cathode to prevent the max7219 from trying to source current into the cathode when it was put into shutdown mode.
Now that I think about it tho:
In common cathode,  cathode goes to 7219 to prevent it from driving matrix cathodes high when in shutdown
In common anode, anode goes to 7219 to prevent it from pulling matrix anode low when in shutdown
In both cases, the non-driving 7219 is isolated from the common pin so the other part can control the shared line.
I'll draw this up when I get home.
« Last Edit: November 07, 2012, 03:10:01 pm by CrossRoads » Logged
Dual MAX7219 controlling common cathode two-color array
And the common anode version, haven't filled it out as much but one can get the idea
Raleigh, NC.
Addicted to Arduino
Crossroads, I just built a single 8 x 8 on a protoboard and used your code in this forum...pretty cool...displays a checker board type matrix lit up that shifts back and fourth...nice..
Thanks Aaron.
If you're seeing the checkerboard, then you are running old code.
I have posted, for you, the new code that works much better.  I suggest you find that.
Pages: 1 [2]   Go Up
