Author Topic: DTMF MT8870 with arduino for robot  (Read 803 times)
I have attached my arduino to a MT8870 like in the following diagram:
http://www.pablin.com.ar/electron/circuito/telefon/decdtmf/circuito.gif
Problem is that only one column of keys seems to work. This column changes from phone to phone- I have tested this with 2 phones.
I have not installed any pull up/pull down resistors and nor is there any buffering b/w the outputs of the MT8870 and arduino, i.e. they are connected directly. Any plausible reason why this is not working?
Thanks
code? actual schematic in use?
-j
nr Bundaberg, Australia
You should have resisters because the outputs go tri-state when no signal is present, I'd use the internal pullup ones. Buffers should not be required.
What have you got StD connected to? And post your code.
______
Rob
