Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: HELP Please - Idiot Dad tells his kid he can make a rocket launcher with a Ardui  (Read 2530 times)
Offline Offline
Full Member
View Profile
My response wasn't just a correction; it is different code.
It will work and allows you to put in all the checks you want and they'll have instant response as delay() is not used.
The code will look clean if you create a separate subroutine just for the checks.
It returns a zero if all is OK, otherwise it returns an abort code number.
Think of "millis()" as if it were better named to be "currentTimeFromLongAgoInMilliseconds()"
Code:
int LauncherSystemCheck()
    if ( checkRelayPower() != 0 )
         return 1;
    if ( IgnitorContinuity() != 0 )
         return 2;
    if ( KeyInserted() != 0 )
         return 3;
    return 0;
   int abortCode = LauncherSystemCheck();
   if (abortCode != 0)
       Serial.print("Abort!  code = ");
       Serial.println(abortCode);
       while (true)
          ;                       // Never start - infinite loop
   int  new_elapsed_seconds = (millis() - startTime) / 1000;
   if (new_elapsed_seconds != elapsed_seconds)
        elapsed_seconds = new_elapsed_seconds;
        Serial.println(blastoff_seconds - elapsed_seconds);
        if (elapsed_seconds == blastoff_seconds)
              Serial.println("Blast Off!");
              // do Blastoff!
Logged
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Happy Father's Day! Hope you're having a great time with your offspring and this project. We're model rocketeers from way back. Here's a sketch to try, maybe it will help get past the countdown part. It's just a demo, no LCD, etc., and does not attempt to address all the features and requirements posted earlier smiley-eek
Code:
#include <Button.h>        //https://github.com/JChristensen/Button
#include <Streaming.h>     //http://arduiniana.org/libraries/streaming/
#define BUTTON_START 4     //wire from pin 4 to ground
#define BUTTON_ABORT 5     //wire from pin 5 to ground
#define redLED 6           //wire from pin 6 to ground through appropriate current limiting resistor (e.g. 330 ohm)
#define grnLED 7           //wire from pin 7 to ground through appropriate current limiting resistor (e.g. 330 ohm)
#define PIEZO 8            //wire from pin 8 to ground through appropriate current limiting resistor (e.g. 100 ohm)
#define DEBOUNCE_MS 25     //debounce interval (ms)
#define COUNTDOWN_SEC 10   //number of seconds to countdown from
Button btnStart(BUTTON_START, true, true, DEBOUNCE_MS);    //instantiate the buttons, pullups on, inverted logic
Button btnAbort(BUTTON_ABORT, true, true, DEBOUNCE_MS);
unsigned long ms;          //the time from millis()
unsigned long msCount;     //time when the count was changed
unsigned long msLED;       //time when the LED was turned on
int count;                 //the countdown counter
enum {START, STANDBY, COUNTDOWN, ABORT, LAUNCH, WAIT};    //states for the state machine
uint8_t STATE;             //current state machine state
void setup(void)
    pinMode(redLED, OUTPUT);
    pinMode(grnLED, OUTPUT);
    pinMode(PIEZO, OUTPUT);
void loop(void)
    ms = millis();
    btnStart.read();
    btnAbort.read();
    switch ( STATE ) {
        case START:
            noTone(PIEZO);
            digitalWrite(redLED, LOW);
            digitalWrite(grnLED, HIGH);
            Serial << endl << "Stand by to begin countdown sequence..." << endl;
            STATE = STANDBY;
        case STANDBY:
            if ( btnStart.wasPressed() ) {
                count = COUNTDOWN_SEC;
                tone(PIEZO, 1500, 800);
                digitalWrite(redLED, HIGH);
                digitalWrite(grnLED, LOW);
                msCount = ms;
                msLED = ms;
                STATE = COUNTDOWN;
                Serial << "Countdown: " << _DEC(count) << " ... ";
        case COUNTDOWN:
            if ( btnAbort.wasPressed() ) {
                STATE = ABORT;
            if ( ms - msLED >= 500 && count > 1) {
                msLED = ms;
            if ( ms - msCount >= 1000 ) {
                msCount = ms;
                msLED = ms;
                tone( PIEZO, 1500, --count == 1 ? 900 : 100 );
                if ( count == 0 )
                    STATE = LAUNCH;
                    Serial << _DEC(count) << " ... ";
        case ABORT:
            Serial << endl << "Countdown aborted at T-" << _DEC(count) << " seconds!" << endl;
            STATE = START;
        case LAUNCH:
            tone(PIEZO, 2000, 1000);
            msLED = ms;
            Serial << "LAUNCH!" << endl;
            STATE = WAIT;
        case WAIT:
            if ( ms - msLED >= 2000 ) STATE = START;
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Somerset UK
Offline Offline
Newbie
View Profile
Hi
Thanks for all the ideas and help
Techylah
Your code looked perfect for what i want to do, so I removed the safety check part for now and just used the timer part
I added the entries into globals and startup
and this into the countdown loop
Code:
  void CountDown2()
 lcd.clear();
        lcd.print(cdt - elapsed_seconds);
          Serial.println(cdt - elapsed_seconds);
        if (elapsed_seconds == cdt)
              fire();
} // end CountDown
But it does not run it just returns to the main menu?
It also prints a randon negative number to the serial monitor and LCD
fire() never runs
Any ideas?
Logged
Sometimes, it's not as easy as you think.....
Somerset UK
Offline Offline
Newbie
View Profile
I have just uploaded the full code to here, you will probally find the problem if you can see all the code
http://lowerstoford.co.uk/files/test.zip
Logged
Somerset UK
Offline Offline
Newbie
View Profile
serial monitor debug output
Start Up
Load Main Menu
Auto Selected
Auto Mode
CountDown2 Start
-8
CountDown2 end
Load Main Menu
« Last Edit: June 17, 2012, 03:05:26 pm by lowerstoford » Logged
Offline Offline
Full Member
View Profile
I searched all the code in your zip file.  I do not see any Serial.print statements that include "CountDown2", as in your "CountDown2 Start" or "CountDown2 end"
Perhaps that is not the same code.  Also, better indentation would make the code much more readable.
Logged
California
Offline Offline
Newbie
View Profile
WWW
Ok, for the wireless you could use the xbee wireless module, or for cheaper, you could use a wireless adapter, and a router running openwrt. For the buttons and stuff I think you should break them down into pieces. ex: make that keypad so it can take the input and convert to a countdown, save that code and setup once you get it working. Next make a button that starts a timer, and save that code and get it working, then go to your fail-safe key etc. and when  you are done combine all the code. It's easier to troubleshoot when it's in small bits so you can locate the problem easier.
Logged
Proud Member of the Nighthawk Robotics Club Team 569 B
Somerset UK
Offline Offline
Newbie
View Profile
***********UPDATE***********
I thought I would update you all on this project
Firstly I would like to thank everyone for all the help and advice and I would also like to apologise for not replying and updating this post.
This project has been very slow to progress, due to the massive learning curve I have encountered and work/family commitments
The Controller unit is now 98% complete, the knowledge I have gained through the development of this part of the system should hopefully allow me to complete the Pad unit very quickly.
I will add some images of the project over the next few days/weeks and I hope to be preforming live tests on the system in early November.
I am planning to use the system to launch our new rocket (Armstrong 2012) before the end of the year.
More updates to follow...............
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
