Loading...
Pages: [1]   Go Down
Author Topic: DG408 wiring  (Read 280 times)
Offline Offline
Jr. Member
View Profile
Hello, I have DG408 (http://datasheets.maximintegrated.com/en/ds/DG408-DG409.pdf)
and it says in the following scheme that there is V+, V- and gnd, what does V- stands for?
thanks in advance,
Logged
Offline Offline
Full Member
View Profile
thanks in advance,
Just what it says negative supply voltage.  That chip normally runs with 15v +- but supports a lot of different configurations. If you want to use it with positive voltage only connect v- to gnd as the datasheet says on page 6.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
If you were running from dual supply, like +12V/-12V, V- would be -12V.
If running from single +5 supply, V- goes to Gnd, per page 4.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
Thats what I thought,
thanks for the quick reply.
Logged
Pages: [1]   Go Up
Print
Jump to:
