Topic: Bootloading Atmega328p-pu with USBTiny AVR Pocket Programmer (Read 11410 times) previous topic - next topic
dgrigg123
Sorry ahead of time for the large message, but I know that details are usually appreciated in helping debug issues.
This is Part 1 of a few Parts, because of the exceeded size limit :D
I am having problems boot loading and loading sketches to the Atmega328p-pu chip.
Let me start by defining a few things:
I am using a windows 7 (64bit) platform
Arduino IDE 1.0
Avrdude 5.10
Pocket AVR programmer (https://www.sparkfun.com/products/9825
FT232RL USB to Serial breakout board (https://www.sparkfun.com/products/718)
And I followed the procedure to build a breadboard for boot loading and programming from: http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard
I quadruple checked my setup numerous times to make sure it was correct.
Note:  I did have to pin test the AVR programmer 6-pin connector and found that it has to be inserted in the opposite direction as shown in step 6.3 http://itp.nyu.edu/physcomp/uploads/arduinobload_plugin.jpg.  The supplied 6-pin has to go in the opposite direction from what is shown in this image.
Step 6.4 "Time to Burn" does not work and lead me down the following path:  Using AVRdude directly for the boot load.
I had issues getting the drivers all installed, but in the end, I basically followed the procedure details outlined by BeagleBoy at the top of the comments list at: https://www.sparkfun.com/products/9825
It did not work fist time and had to uninstall and reinstall a couple of times, but in the end, I have the following results in DeviceManager when both the Programmer and USB FT232RL are plugged in:
Device Manager:  (Partial list)
- LibUSB-Win32 Devices
 - USBtiny
- Ports (Com & LPT)
 - USB Serial Port (COM4)
- Other Devices
 - Unknown device
To try using the Arduino IDE 1.0 to program the boot loader, I do the following:
Tools/Board:  Set to Arduino Uno
Tools/Serial Port:  Com4 is selected and recognized, i.e. the FT232R is seen.
Tools/Programmer: Set to USBtinyISP
Files/Preferences:  select verbose output for both compilation and upload.
Then, running Tools/Burn Bootloader, I recieve the following message:
C:\Program Files (x86)\arduino-1.0\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cusbtiny -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "C:\Program Files (x86)\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
        Using Port                    : lpt1
        Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
        AVR Part                      : ATMEGA328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : USBtiny
        Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 53 53]
Reading | CMD: [30 00 00 00] [53 73 73 73]
CMD: [30 00 01 00] [73 73 73 73]
################CMD: [30 00 02 00] [73 73 73 73]
################################## | 100% 0.01s
avrdude: Device signature = 0x737373
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
        Double check chip, or use -F to override this check.
avrdude done.  Thank you.
I think that the bottom line is that the Device Signature is wrong.  I have tried a couple of chips and each returns 0x737373 for the signature.  I also noticed that in the message above it says "avrdude: programmer operation not supported".  Not sure if this is also an issue or not.
My largest issue is WHY do I always get a 0x737373 return from any of the Atmega328p-pu chips that I put in?
Shouldn't it be reading 1E 95 0F for this chip???
Next step in next message below...
dgrigg123
#1
Oct 10, 2012, 04:59 pm Last Edit: Oct 10, 2012, 05:21 pm by dgrigg123 Reason: 1
Part 2/3:
So I accept the fate of my chips having a different signature than expected, so I go and change the expectation to move forward.
If I go to Arduino-1.0/hardware/tools/avr/etc/avrdude.conf and edit the following section to change the signature that Arduino AVRdude uses for the check, as below.
# ATmega328P
part
   id = "m328p";
   desc = "ATMEGA328P";
   has_debugwire = yes;
   flash_instr = 0xB6, 0x01, 0x11;
   eeprom_instr = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
 0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
 0x99, 0xF9, 0xBB, 0xAF;
   stk500_devcode = 0x86;
   # avr910_devcode = 0x;
#    signature = 0x1e 0x95 0x0F;
signature = 0x73 0x73 0x73;
   pagel = 0xd7;
With this change I then get the following result from boot loader:
        Using Port                    : lpt1
        PAGEL                         : PD7
        BS2                           : PC2
        RETRY pulse                   : SCK
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
CMD: [a0 03 fc 00] [73 f3 f3 ff]
CMD: [a0 03 fd 00] [ff ff ff ff]
CMD: [a0 03 fe 00] [ff ff ff ff]
CMD: [a0 03 ff 00] [ff ff ff ff]
avrdude: erasing chip
CMD: [ac 80 00 00] [ff ff ff ff]
This all occurs way to fast and it is not boot loading.
So, I give up on boot loading from Arduino IDE and go directly to the Avrdude.....
See next message for the steps I followed next....
dgrigg123
#2
Oct 10, 2012, 05:07 pm Last Edit: Oct 10, 2012, 05:21 pm by dgrigg123 Reason: 1
Part 3/3:
Here is the step by step sequence of my activities, so please follow along.  I tried to be as detailed as possible.
I try to run the AVRdude command shown at: https://www.sparkfun.com/products/9825, which is:
avrdude -c usbtiny -B 1 -patmega328 -U flash:w:main.hex
However, avrdude replies that "atmega328" not found.
So, I change to:
avrdude -c usbtinty -B 1 -pm328p -U flash:w:main.hex
However, I get...initialization failed, rc=-1
I read that this may be due to a high baud rate, so I change to:
avrdude -c usbtiny -B 32 -pm328p -U flash:w:main.hex
Now, avrdude is reporting the same thing that Arduino IDE boot load did, i.e.:
So, I follow the same logic as before to change avrdude's expected signature and go to C:\WinAVR-20100110\bin\avrdude.conf and edit the following section to change the signature that Arduino AVRdude uses for the check, as below.
# ATmega328P
part
   id = "m328p";
   pagel = 0xd7;
   bs2 = 0xc2;
Now, when I run,
I get:
avrdude: NOTE: FLASH memory has not been specified, an erase cycle will be performed.
To disable this feature, specify the -D option.
So I do this and command:
avrdude -c usbtiny -B 32 -pm328p -D -U flash:w:main.hex
Now avrdude complains that "main.hex" No such file or exists, and it is in Safemode with questions:
lfuse was 73, now ff, change back?
lfuse was 7b, now ff, change back?
lfuse was 3, now 7, change back?
I say no to each, as yes causes things to hang up.
I find a copy of "optiboot_atmega328.hex" and use it instead.
Now I command,
avrdude -c usbtiny -B 32 -pm328p -D -U flash:w:optiboot_atmega328.hex
Awsome...things start to Write and read, but still to Device signature 0x737373
and the resulting message for the process is:
C:\>avrdude -c usbtiny -B 32 -pm328p -D -U flash:w:optiboot_atmega328.hex
Reading | ################################################## | 100% 0.04s
avrdude: reading input file "optiboot_atmega328.hex"
avrdude: input file optiboot_atmega328.hex auto detected as Intel Hex
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 46.03s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against optiboot_atmega328.hex:
avrdude: load data flash data from input file optiboot_atmega328.hex:
avrdude: input file optiboot_atmega328.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 43.63s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
        0xff != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was 73, and is now 0
Would you like this fuse to be changed back? [y/n] n
avrdude: safemode: hfuse changed! Was 7b, and is now 0
avrdude: safemode: efuse changed! Was 3, and is now 0
avrdude: safemode: Fuses OK
All looked good, except the verification process, AND it does not look like the fuses were set properly, AND I still have this annoying Device signature issue.
In the end, even though this occurs, I guess this is why I cannot load a Blink sketch through Arduino IDE, as I get the following error in Arduino IDE trying to upload the sketch...
        Using Port                    : \\.\COM4
        Using Programmer              : arduino
        Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
Sorry for the long winded explanation, but I wanted all the details out there for whomever can help me here.
Otherwise, I just go and spend the extra $1 for a pre-boot loaded chip and succumb to failure as a boot loader.
Thanks for any advice and help.
dgrigg123
As an added note:
I tried to set the fuses only, using
avrdude -c usbtiny -p m328p -C -U lfuse:w:0xFF:m -U hfuse:w:0xDE:m -U efuse:w:0x05:m
however, it just did not seen to take.
dgrigg123
OK,
I found my issue with the Bootloading part.
There is an error in the picture in the instructions at:
http://itp.nyu.edu/physcomp/uploads/arduinobload_wires.jpg
If you look closely at this picture, it shows the MOSI from the Breakout Board going to Pin 16 of the Atmega.  THIS SHOULD BE GOING TO Pin 17 instead.
Now, with..
avrdude -c usbtiny -B 32 -pm328p -U flash:w:optiboot_atmega328.hex
I get the following result.
C:\>avrdude -c usbtiny -B 32 -pm328p -U flash:w:optiboot_atmega328.hex
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
Writing | ################################################## | 100% 45.89s
Reading | ################################################## | 100% 43.57s
avrdude: 32768 bytes of flash verified
However, I am still not able to load a sketch to the chip using ArduinoIDE 1.0
I get the following....
         Overriding Baud Rate          : 19200
avrdude: Recv:
A little progress, but no sketches yet.  Any ideas?
I can try uploading sketches through avrdude maybe.
dgrigg123
OK,
I can upload the Blink.cpp.hex using avrdude through the AVR Pocket Programmer, BUT I still cannot get it from the Arduino 1.0 interface through the FT232R USB breakout board.
Either way, I seem to have a path that works, not the most convenient, but works.
Now, however, the LED seems to blink about 10 times slower than the 1 sec delay in the program.
Now, can someone tell me why this is?
Thanks,
dgrigg123
OK, I'm learning.
Set the fuses to:
avrdude -c usbtiny -B 16 -p m328p -U lfuse:w:0xFF:m -U hfuse:w:0xDE:m -U efuse:w:0x05:m
And the LED blinks at the proper rate, using my external 16MHz crystal.
Still need any input on my issue using Arduino IDE through the FT232R.
Thanks
dgrigg123
On the road to determine why I get "stk500_getsync(): not in sync: resp=0x00" when I try to load a sketch from Arduino 1.0 IDE interface....
I still get this message when trying to upload a sketch.
However, if I load the following modified Blink sketch, using still avrdude to upload through the Pocket Programmer...
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  Serial.println("High");
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
  Serial.println("Low");
I can then see if I receive Serial (COM4) messages through the FT232R Breakout board, on COM4.
And I do.
So I can read Serial messaging through the FT232R, but I just cannot upload a sketch.
Go figure.
dgrigg123
I can use the "Upload using Programmer", if I have the usbtiny selected in the Arduino IDE.
So I guess for now I can give up on using the FT232R breakout to load sketches.  Otherwise, I will just use it for reading serial output for debug.
CrossRoads
It sounds like you may have a data speed mismatch between what the bootload is using and what the PC/IDE is using.
If you put the Uno optiboot booloader on the chip, and then select Uno as board type, that  may fix things for you.
dgrigg123
CrossRoads,
Thanks for the reply.  I was starting to think I was alone in the world.
With Optiboot loaded on the chip, I have Uno selected but still cannot successfully load a sketch from Arduio IDE through the FT232R, even though the FT232R shows up as COM4 and COM4 is selected and I can get serial Read/Write through the FT232R on COM4.
When I load a sketch using avrdude, I have to use the "-B 32" or "-B 16" flag, as a "-B 1" setting results in a "initialization failed, rc=-1" error in avrdude.
I don't know how to control these types of options when Arduino IDE uploads sketches, as Arduino is simply using its own avrdude also.  I might be wrong, but it seems like if I can dictate the bit clock period when Arduino transfers, that maybe it would work.
Also a question of mine, in general, my COM4 is set to 9600 baud but in the "boards.txt" the uno.upload.speed=115200.  Is that a right?  I tried to lower this to 19200 but no change.
CrossRoads
I'ved only programmed via the IDE, I'll leave the avrdude questiosn to someome with experience.
retrolefty
The baud rate a specific bootloader uses is 'hard coded' into the bootloader code, it is not changeable, so the IDE looks at the boards.txt file and uses the baud rate value from the selected board entry in that file for the board selection choice you had set in the IDE.
Lefty
dgrigg123
Lefty,
Thanks, but I am a little confused by your comment.  Help me understand please.
In my current situation I want to simply sketch-load rather than boot-load.  (I'm not sure if there is really a fundamental difference in this designation in the IDE, but my brain is wired to think like that for the moment.)  But for the sake of argument, I can do neither from the IDE through my FT232R, so I understand that the issue is likely the same either way.
So when you say "The baud rate a specific bootloader uses is 'hard coded' into the bootloader code", are you meaning that the baud rate a specific device, in my case the FT232R, used for either boot or program loading is hard coded?
Secondly, you said "the IDE looks at the boards.txt file and uses the baud rate value from the selected board entry in that file for the board selection choice you had set in the IDE".
So, is it important that the baud rate listed in the boards.txt match what is hard coded in the bootloader device?
retrolefty
Lefty,
With the present IDE release there are two very different ways to upload a sketch to an Arduino board (or standalone target chip). The first is the way that was always been available in the IDE and that is to use a serial link from a PC com port (or PC USB virtual com port) to a arduino board that has both a USB serial converter chip (either a FTDI or AVR based USB serial converter chip) and ALSO has had a bootloader program burned into the 'target' chip (as all purchased arduino board have). The bootloader that was burned into the chip uses a baud rate value to use that is specific to that version on bootloader. So that is why you must select the board type in the IDE that properly matches the baud rate and board clock speed  that the board you attach to the PC.
The second newer method to upload sketches to a arduino board with the IDE is using the IDE file menu option of 'upload using programmer' option. This method uses whatever hardware programmer device you select in the IDE to use the ISP protocol method to burn a sketch into a board that is attached to the hardware programmer. This method because it's not using serial com to talk to the board does not require that their is a bootloader program already installed into the target arduino chip you wish to upload to.
The IDE tells the PC com port what speed to use when doing a serial upload operation based on the speed that the board selected option tells it to use. The arduino board's bootloader when started at power-up or auto reset expects the com port speed to be at the specific speed that bootloader expects it to be at.
Yes, it must match unless you are using a hardware programmer that uses ICSP method to burn the sketch.
Lefty
