Topic: atmega324p bootloader can't write flash [SOLVED] (Read 2043 times) previous topic - next topic
frpr666
Oct 10, 2012, 09:18 pm Last Edit: Oct 11, 2012, 09:28 pm by frpr666 Reason: 1
Hello,
1/ I have device atmega324p, I downloaded the bootloader from site: https://github.com/magnuskarlsson/SDLogger/wiki/Arduino-howto
2/ I modified a little bit the "Makefile" and "ATmegaBOOT.c" for chip atmega324p, speed 19200, cpu_speed 16MHz
3/ I burned it by avrdragon
4/ I joined RS232-TTL (max232) cabel to PC and to the chip
5/ I made a successful test:
$ avrdude -c avrisp -p m324p -P com1 -b 19200 -F -U flash:r:readout:i
6/ but writing doesn't work
$ avrdude -c avrisp -p m324p -P com1 -b 19200 -F -U flash:w:main_blinking.hex:i
What is wrong?
Please any advice how to upload atmega324p chip?
Or does someone provide Arduino IDE files for chip atmega324p?
Tom Carpenter
#1
Oct 10, 2012, 11:35 pm Last Edit: Oct 10, 2012, 11:48 pm by Tom Carpenter Reason: 1
You have specified to avrdude to program the chip using ISP (note the avrisp), and yet you are trying to use a bootloader. The two are very different.
Off the top of my head I can't remeber what ATmegaBOOT uses in relation to avrdude. I think that optiboot is 'arduino' (instead of avrisp), or is it 'stk500v1'. Would have to check.
EDIT:
Try this:
avrdude -c arduino -p m324p -P com1 -b 19200 -D -U flash:w:main_blinking.hex:i
~Tom~
frpr666
Thank you. Today I have found the bug. I forgot change line 119 in ATmegaBOOT.c for chip m324p. Now it works both reading & writing.
Bootloader code is here: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=1000323#1000323
$ avrdude -c avrisp -p m324p -P com5 -b 19200 -F -D -U flash:r:readout.hex:i
$ echo 'this one reads the chip'
$ avrdude -c avrisp -p m324p -P com5 -b 19200 -F -D -U flash:w:main.hex:i
$ echo 'this one writes the chip'
$ echo '-c arduino instead of -c avrisp works too'
