Topic: Function for incrementing variable every 1000 ms (Read 437 times) previous topic - next topic
steskaniarduino
Is making this Function for incrementing variable every 1000 ms good for measuring realtime power consumption in Wh . If it is what is the best way to vrite that kind of function. Thanks
KeithRB
Don't use a function. Just put a section of loop that fires every 1000 ms. Check out Blink without delay and just increment your variable instead of blinking.
steskaniarduino
Not sure if i know how to do it I am just beginner :S
aarg
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
KeithRB
The IDE includes the blink without delay example. Load it and read it.
steskaniarduino
This is code for measuring power consumption and current
Code: [Select]
#include <LiquidCrystal.h>
const int sensorIn = A0;
int mVperAmp = 66;
double Voltage = 0;
double Power = 0;
double VRMS = 0;
int time = 0;
double AmpsRMS = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/*time counter*/
unsigned long previousMillis = 0;
const long interval = 1000;
void setup(){
lcd.begin(16,2);
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
lcd.setCursor(0,0);
lcd.print("I=");
lcd.print(AmpsRMS);
lcd.print(" A");
Power = 220*AmpsRMS;
  lcd.setCursor(7,0);
  lcd.print("P=");
  lcd.print(Power,2);
  lcd.print(" W");
if(currentMillis - previousMillis >=interval){
time++;
lcd.setCursor(0,1);
lcd.print(whC(int time, float Power ),2)
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1023; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1023.0;
return result;
float whC(int time, float Power ){
float result;
result = (Power * time)/3600;
return result;
KeithRB
Looks pretty good, you need to reset previousmillis inside the time check loop so it happens again 1 second later
