Author Topic: Arduino Sleep with XBee  (Read 901 times)
Texas, USA
Arduino rocks!!
I just wanted to know when I put my Arduino in a low power state mode, will the XBee use less power as well, or would I have to put the XBee in its own low power state?
Working on a Smart Home Management System. Visit my blog: http://tae09.blogspot.com/ to find out more, and to keep track with the project.
If you're not living on the Edge, you're taking up too much space!
It does use less power when it's not transmitting.  To lower it further you can use the sleep pin.
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
Texas, USA
Arduino rocks!!
Would you happen to know what the power consumption is when idle?
Grand Blanc, MI, USA
CODE is a mass noun and should not be used in the plural or with an indefinite article.
Here are specs for the XBee 802.15.4 (S1) and the XBee ZB (S2) low-power modules. The Pro (high-power) modules require significantly more current in transmit mode. See the Specifications in the product manuals for details, XBee 802.15.4 or XBee ZB.
XBee 802.15.4 (S1)
Supply Voltage 2.8 – 3.4 V
Transmit Current (typical) 45mA (@ 3.3 V)
Idle / Receive Current (typical) 50mA (@ 3.3 V)
Power-down Current < 10 μA
XBee ZB (S2)
Supply Voltage 2.1 - 3.6
Operating Current (Transmit, max output power)
    40mA (@ 3.3 V, boost mode enabled)
    35mA (@ 3.3 V, boost mode disabled)
Operating Current (Receive)
    38mA (@ 3.3 V, boost mode disabled)
Idle Current (Receiver off) 15mA
Power-down Current < 1 µA @ 25°C
MCP79411/12 RTC ... "One Million Ohms" ATtiny kit ... available at http://www.tindie.com/stores/JChristensen/
Texas, USA
Arduino rocks!!
Thanks.
