Author Topic: SoftwareSerial example not working as expected?  (Read 413 times)
EDIT: I'm using a arduino Uno SMD version
Hi all,
If i use the sofwareserial example which comes with the arduino distribution (1.0.1 on windows 7, softwareserial version ?? ) the output is not as expected.
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 2 (connect to TX of other device)
 * TX is digital pin 3 (connect to RX of other device)
 created back in the mists of time
 modified 9 Apr 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
  Serial.begin(57600);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
if i input 1 2 3 4 5 6 7 8 9 (seperated) i get this response:
þþÿÿÿÿþþþ
if i change
to
Serial.print(mySerial.read());
the output becomes:
ÿÿÿÿÿÿÿÿÿ
which looks like a timing issue to me...
Anyone experience with this possible bug?
« Last Edit: October 11, 2012, 03:56:41 am by dieselboris » Logged
Gosport, UK
What 'other device' are you connecting to?
a GPRS modem on a breakoutboard from linksprite:
http://www.linksprite.com/product/showproduct.php?id=187&lang=en
UK
if i change
to
I'm not sure I see the difference.
Excuse me, typo. See my edit!
Melbourne, Australia
Shannon Member
Lua rocks!
The Leonardo does not seem to support pin change interrupts on those pins, hence software serial won't work on them.
http://arduino.cc/en/Hacking/PinMapping32u4
Shannon Member
Lua rocks!
In addition to that, I'm not certain that SoftwareSerial has been rewritten to take into account the mappings for the Leonardo. It may have been, it may not.
Forgot to mention, but i'm on a arduino Uno SMD.
Gosport, UK
Is your modem configured to repeat whatever it gets sent? If not, what would you expect it to reply when you send it '1 2 3 4 5 6 7 8 9'?
