Loading...
Pages: [1]   Go Down
Author Topic: Using D0 and D1  (Read 296 times)
Offline Offline
Newbie
View Profile
I am finding that pins D0 and D1, which double up as RX and TX do not go LOW when instructed do so so.
Presumably they can be used to do so, or they would not be part of the input/output.
Can anyone tell me how to do this please?
Chris.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Did you make a pinMode call to set them to be outputs? It would help if you posted your code.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Newbie
View Profile
Hi,.
Thanks - Yes I did. Code below:
Thanks,
Chris
  Serial.begin(13600);
  pinMode(10, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(2,OUTPUT);
  pinMode(1,OUTPUT);
  pinMode(0,OUTPUT);
  int units=0;
  int tens=0;
  int counter=0;
  while (counter < 100)
tens=int(counter/10);
units=counter-10*tens;
if (units==0)
digitalWrite(13,HIGH);
digitalWrite(12,HIGH);
digitalWrite(11,HIGH);
digitalWrite(10,HIGH);
digitalWrite(9,HIGH);
digitalWrite(8,HIGH);
digitalWrite(7,LOW);
if (units==1)
digitalWrite(13,LOW);
digitalWrite(12,LOW);
digitalWrite(9,LOW);
digitalWrite(8,LOW);
if (units==2)
digitalWrite(11,LOW);
digitalWrite(7,HIGH);
if (units==3)
if (units==4)
if (units==5)
digitalWrite(10,LOW);
if (units==6)
if (units==7)
if (units==8)
if (units==9)
if (tens==0)
digitalWrite(2,HIGH);
digitalWrite(1,HIGH);
digitalWrite(0,HIGH);
digitalWrite(6,HIGH);
digitalWrite(5,HIGH);
digitalWrite(4,HIGH);
digitalWrite(3,LOW);
if (tens==1)
digitalWrite(2,LOW);
digitalWrite(1,LOW);
digitalWrite(5,LOW);
digitalWrite(4,LOW);
if (tens==2)
digitalWrite(0,LOW);
digitalWrite(3,HIGH);
if (tens==3)
if (tens==4)
if (tens==5)
digitalWrite(6,LOW);
if (tens==6)
if (tens==7)
if (tens==8)
if (tens==9)
counter=counter+1;
if (counter==100) counter=0;
delay (500);
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Code below:
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
As explained in the sticky, which I hope you read:
Read this before posting a programming question
As for your issue, there are pull-ups between the USB interface chip and the Atmega328 which probably accounts for what you are seeing.
Quote
Code:
if (units==0)
if (units==1)
You may want to look up how to use arrays. This would be incredibly difficult to maintain.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Code:
You are starting Serial, then trying to manipulate the pins it uses.
Logged
Offline Offline
Newbie
View Profile
Thank you - that's great smiley
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
In other words, remove the Serial.begin() call.
Logged
Pages: [1]   Go Up
Print
Jump to:
