Topic: SoftwareSerial example not working as expected? (Read 2055 times) previous topic - next topic
dieselboris
Oct 11, 2012, 09:30 am Last Edit: Oct 11, 2012, 10:56 am by dieselboris Reason: 1
EDIT: I'm using a arduino Uno SMD version
Hi all,
If i use the sofwareserial example which comes with the arduino distribution (1.0.1 on windows 7, softwareserial version ?? ) the output is not as expected.
Code: [Select]
 Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 2 (connect to TX of other device)
* TX is digital pin 3 (connect to RX of other device)
created back in the mists of time
modified 9 Apr 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
 Serial.begin(57600);
  while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 Serial.println("Goodnight moon!");
 // set the data rate for the SoftwareSerial port
 mySerial.begin(4800);
 mySerial.println("Hello, world?");
void loop() // run over and over
 if (mySerial.available())
   Serial.write(mySerial.read());
 if (Serial.available())
   mySerial.write(Serial.read());
if i input 1 2 3 4 5 6 7 8 9 (seperated) i get this response:
þþÿÿÿÿþþþ
if i change
Code: [Select]
to
Code: [Select]
Serial.print(mySerial.read());
the output becomes:
ÿÿÿÿÿÿÿÿÿ
which looks like a timing issue to me...
Anyone experience with this possible bug?
dxw00d
What 'other device' are you connecting to?
dieselboris
a GPRS modem on a breakoutboard from linksprite:
http://www.linksprite.com/product/showproduct.php?id=187&lang=en
AWOL
Quote
if i change
Code:
to
Code:
I'm not sure I see the difference.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
dieselboris
nickgammon
Code: [Select]
The Leonardo does not seem to support pin change interrupts on those pins, hence software serial won't work on them.
http://arduino.cc/en/Hacking/PinMapping32u4
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
In addition to that, I'm not certain that SoftwareSerial has been rewritten to take into account the mappings for the Leonardo. It may have been, it may not.
dieselboris
Forgot to mention, but i'm on a arduino Uno SMD.
dxw00d
Is your modem configured to repeat whatever it gets sent? If not, what would you expect it to reply when you send it '1 2 3 4 5 6 7 8 9'?
