Topic: Sketch examples of scrolling text on 8x8 LED matrix w/ MAX72xx (Read 36285 times) previous topic - next topic
bratan
I like the idea of using the 8x8 matrix blocks, beats the hell out of hand soldering 128 individual LED's. I might be tempted to do a smaller wordclock using these.
Thanks Riva! :)
Yeah those 8x8 blocks are super cheap these days. I got 10 of them for $15 on ebay!
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, etc.
Pedro147
#31
Oct 22, 2012, 10:55 pm Last Edit: Oct 22, 2012, 10:57 pm by Pedro147 Reason: 1
Hi Bratan,
Very impressive for someone who recently said
"Thanks!  Honestly I don't really understand any of it (it's a little too advanced for me at this stage), but I will try! :) I need to read some more about SPI..."
Although I realise that that was specifically in regard to SPI, I wish that I could pick this up as quickly as you seem to have. Hopefully I can look through this code and try to understand how I can eventually write my first scrolling text code.   8)  wish me luck Pedro.
http://www.pedroduino.com
bratan
Hi Bratan,
Yeah I was absolutely clueless when I started, but persistence paid off I just refused to give up.  You have to try and try and try again, until it starts to make sense.  The way I eventually figured it out is that I drew everything on paper, made excel spreadsheet, tracked every iteration of for loops, values of variables, tons of Serial.printl commands.  Try to come up with general plan/algorithm first, describe it in words before you start writing code. I had very little success until I drew all matrix screens and pixels in the spreadsheet, all 16 frames of it and described what is happening. At that point I knew exactly what to do and it compiled and worked almost right away, like magic!  Wish you lots of luck Pedro, and let me know if you have a question!
Pedro147
If I knew how to give karma points I would certainly send one your way  8) And you may regret your generous offer
sdtag
I am having a heck of a time trying to scroll text.
I keep getting this error message:
exit status 1
'prog_uchar' does not name a type
and the sketch won't load.
What am I doing wrong?
INTP
exit status 1
You aren't doing anything wrong, per se. It's just an old code you're copying and Arduino IDE changed how to handle progmem stuff.
I played with this some time back but I think just adding
typedef const char prog_uchar;
somewhere before your setup/loop should fix it.
