Topic: 2 pin RGB rainbow-LED (Read 8215 times) previous topic - next topic
o_lampe
Just stumbled across a neat LED that shows rainbowcolors by itself:
http://www.superbrightleds.com/moreinfo/component-leds/rgb-slow-color-changing-led/778/
Has only 2 pins and with a few of these you can make a real multicolor rainbow. Just switch them on separately with a  four seconds delay.
frollard
it would work but they don't have accurate timing in their internal processors, so the temporal drift would make them do random things as they heated and cooled differently.  It only takes a miniscule change at 'megahertz' to multiply quickly into a real distortion.
o_lampe
Makes sense...
Would be a bit overkill to use these LEDs and syncronize them by sampling their color.  :smiley-roll:
Grumpy_Mike
Not only overkill but it would not work. The only control you have over them is on or off, you have no way to synchronize them.
dhenry
Quote
That by itself can be an interesting effect.
Or you can synchronize them by turning them off / on quickly periodically.
dhenry
Quote
You can sample its current: at some point it is going to cycle all of leds off - that's when you can synchronize them. It does require two pins per led for this to work.
