Topic: [solved]Driver issue? (Read 978 times) previous topic - next topic
kduin
Oct 11, 2012, 08:13 pm Last Edit: Oct 12, 2012, 07:48 pm by kduin Reason: 1
Hi there,
i connected my new Leonardo to my PC the first time yesterday. (Win 7 x64, IDE 1.0.1)
I had to install the driver manually using the device-manager.
All worked just fine for about 2 hours, but suddenly i couldn't upload sketches to my board anymore.
I took a look into the device manager, and the arduino were listed as "Unknown Device".
From then on, everytime i plug the board to my pc, the Arduino gets recognized as "Arduino Leonardo" for about 10 seconds, but then it switches to "Unknown Device".
I tired re-installing the drivers and such things, but i can't work with it either way.
Thanks for your help!
kduin
Coding Badly
Anything on the board getting hot?
Anything connected to the board?
Have you tried a different USB cable?
Have you tried a different USB port on the computer?
kduin
#2
Oct 11, 2012, 08:47 pm Last Edit: Oct 11, 2012, 08:49 pm by kduin Reason: 1
thanks for your fast response.
No.
Nothing.
Only have one cable with this particular connector, so no.
Not working with usb-hub nor direct to the mainboard-plugs.
Any other ideas?
Coding Badly
Have you tried jiggling the cable?
kduin
Just did, nothing changes.  :(
I had a similar issue (device disconnects from windows after about 12 seconds after I uploaded a sketch), BUT, my device disapears entirely, (bing-bong) I don't have an "Unknown device"...
Just in case it helps...
http://arduino.cc/forum/index.php/topic,126770.0.html
kduin
I tried uploading the blink sketch while the arduino is connected for a few seconds.
I had to try it a few times, but now it's working again!
Thank you so much!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
