Loading...
Pages: [1]   Go Down
Author Topic: Servo Jerk  (Read 337 times)
Offline Offline
Newbie
View Profile
The project we're currently doing for class is requiring us to use a few servo motors to create an animatronics bat.  However I am having coding problems with the servo's. They simply work fine, it will go from one degree to the next, but when it resets to it's original position and goes the other way it seems to jerk real fast and does not look smooth at all.
Any help on how to fix this would be helpful!
Here is my code, it is similar to the one on the arduino reference website, I've just added in a few extra lines.
Code:
#include <Servo.h>
Servo myservoA;
Servo myservoB;
int pos = 0;    // variable to store the servo position
  myservoA.attach(9);
  myservoB.attach(8);
  for(pos = 50; pos < 1; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservoA.write(pos);              // tell servo to go to position in variable 'pos'
    (15);                       // waits 15ms for the servo to reach the position
  for(pos = 140; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 90; pos < 50; pos += 1)  // goes from 0 degrees to 180 degrees
    myservoB.write(pos);              // tell servo to go to position in variable 'pos'
    delay(10);                       // waits 15ms for the servo to reach the position
  for(pos = 0; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
    delay(15);
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Maybe you need a few more useless curly braces in the code.
Or, more likely, you need to tell us how the servos are powered and what load is being applied to the servos.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
Why bother with comments?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline Offline
Tesla Member
View Profile
The start position for each loop is not the same as the end position from the previous loop, so the servo jumps to the start position as fast as it can. If you want a smooth continuous motion, you need to make sure that you don't make any abrupt changes to the servo position. (If the code actually did what the comments implied, you wouldn't have this problem.)
Logged
Pages: [1]   Go Up
Print
Jump to:
