Loading...
Pages: 1 [2]   Go Down
Author Topic: Lifting up to 100 pounds with motor  (Read 1629 times)
UK
Offline Offline
Tesla Member
View Profile
am using a 12 volt lead acid battery at 24 amps an hour for a power supply
Presumable this this means amp-hours (i.e. capacity) rather than amps per hour.
Logged
Offline Offline
Sr. Member
View Profile
it is for capacity but I think it can give out a large amount of amps for a short duration and can give a constant 12 amps (on my testing) without lowering the overall 12 volts too dramatically.
Logged
UK
Offline Offline
Tesla Member
View Profile
Since it seems you have ample power available I suggest you look for a much bigger motor/gearbox designed to cope with forces of this magnitude. I suspect you will find a worm drive works best. They aren't usually very efficient, but I don't think that will be a concern since you have ample power. But they let you generate very high forces very simply, and also protect the motor and transmission from shock loads. They can be designed simply enough to be a realistic DIY job if you have reasonable fabrication skills.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
