Loading...
Pages: [1]   Go Down
Author Topic: stumped on a maths question  (Read 881 times)
uk
Offline Offline
Sr. Member
View Profile
hi
im going to be using a pressure sensor soon, an omron D8M-A1 trying to work out the maths but hit a wall could someone tell me how to work out this figure out please
sensors output is...... 15mv    to   1247mv.
over a pressure range 0 millibar to 49millibar.
i need to know what value when @ 12 milibar,
i thought i had it but then noticed 0millibar was 15mv which threw me out
thank you
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
If the sensor response is linear, then it should be (12/49) * (1247 - 15) + 15 mV.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
Delta V = 1247-15 = 1232mV
Delta P = 49-0 = 49mB
therefore Dv/Dp = 1232/49 = 25.142mV/mB
zero offset = 15mV
Therefore output at 12mB = (25.142*12)+15 = 301.71+15 = 316.71mV
But, the Dv/Dp figure of 25.142 seems rather peculiar and certainly not what you'd expect to find in an industrial environment, where manufacturers endeavoured to use "round" numbers
Are you certain about your numbers?
Logged
Germany
Offline Offline
Edison Member
View Profile
Quote
25.4 is the roundest number I ever saw
Logged
uk
Offline Offline
Sr. Member
View Profile
ok here is the data sheet.
http://www.farnell.com/datasheets/91228.pdf
15 to 1247mV
0 to 4.9 kPa
(0 to 49 milibar)
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
So 15mV is the typical offset voltage at zero pressure. For accurate results, you will need to calibrate the sensor output  - that is, measure the output voltage at zero pressure, then subtract that voltage from the readings you get. Unfortunately, judging from the graph, the offset may (theoretically) be negative at zero pressure.
Logged
Pages: [1]   Go Up
Print
Jump to:
