Topic: How to detect loss of ethernet network? (Read 1 time) previous topic - next topic
iisfaq
I have an Ethernet shield and am using the standard Ethernet library.
What is the best way to detect that for example the network is no longer available?
If I pull a cable out of my PC it knows pretty quickly that it is not there any more.
Is there a status I can check for?
Chris
johnwasser
You should probably look in the WizNet W5100 datasheet to see how to check the Ethernet status.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
SurferTim
The w5200 has a PHYSTATUS register to determine if the interface link is up or not. I do not believe the w5100 has that feature.
iisfaq
Probably a bit of my conform zone - I was hoping there was a quick and simple method.
Chris
