Topic: I Keep getting errors when I try to upload (Read 5468 times) previous topic - next topic
AWOL
You certainly can't just drop in the code to the code you posted earlier, but I don't think it would be a huge amount of work to fix.
Pity the code you have grew so big before you found this flaw.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
AlanFFM
darn. well thanks for the help. If I run into any other problems ill let you know. So basically I need to replace all the LCD lines?
AWOL
Maybe.
I haven't looked too closely at your code, but it may be possible to simply spoof a serial LCD class, leaving the code intact.
That would be my first attempt.
AlanFFM
Sorry for the delay, I had a lot of work on my hands lol.
How would I go about spoofing? From what I understand that means to trick the arduino into thinking its an older version...
Is this safe?
AlanFFM
Ok so still breaking my head with this. I changed some variables and got a new set of errors (which i hope are better then teh old set..)
heres a list of my errors:
sketch_oct15a.cpp: In function 'void setup()':
sketch_oct15a:198: error: 'class NewSoftSerial' has no member named 'init'
sketch_oct15a:199: error: 'class NewSoftSerial' has no member named 'clear'
sketch_oct15a.cpp: In function 'void loop()':
sketch_oct15a:275: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:276: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:281: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:283: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:285: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:287: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:289: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:290: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:291: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:293: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:295: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:296: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:297: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:299: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:378: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:381: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:385: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:388: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:391: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:395: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:398: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:401: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:404: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:407: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:410: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:413: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:427: error: 'class NewSoftSerial' has no member named 'clear'
sketch_oct15a:435: error: 'class NewSoftSerial' has no member named 'clear'
sketch_oct15a:439: error: 'class NewSoftSerial' has no member named 'clear'
sketch_oct15a:446: error: 'class NewSoftSerial' has no member named 'clear'
sketch_oct15a:456: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:463: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:468: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:473: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:478: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:486: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:493: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:498: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:503: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:508: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:518: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:525: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:530: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:535: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:540: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:547: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:548: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:550: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:551: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:553: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:554: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:574: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:578: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:580: error: 'class NewSoftSerial' has no member named 'cursorTo'
sketch_oct15a:585: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:589: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:593: error: 'class NewSoftSerial' has no member named 'printIn'
sketch_oct15a:597: error: 'class NewSoftSerial' has no member named 'printIn'
Heres the relevant code
Code: [Select]
#include <NewSoftSerial.h>
#include <stdlib.h> // for itoa() call
#include <EEPROM.h>
#define LEDPIN  13
/** LCD Shield            */
NewSoftSerial lcd(2, 3);// use both lines
char buf[5]; //used in conversion of int to char for lcd
int configure = 0; //use select as an on/off for configuring
int showReading = 0; //select which value to modify  0-3
int adc_key_in = 1024; //Start with -1 key value
int adc_key_val[5] = {
  100, 160, 360, 770, 800 }; //Analog values from Keys on keypad shield
65, 218, 393, 601,1000};
int NUM_KEYS = 5;
int key= -1;
char trigger_names[4][15] = {
  "Temp Trigger 1",
  "Temp Trigger 2",
  "Humid Trigger",
  "C02 Trigger" };
/* Set up index value for storing values in eeprom*/
int k=0;
  // declare pins as output
  pinMode(LEDPIN, OUTPUT);
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  pinMode(RELAY3, OUTPUT);
  pinMode(RELAY4, OUTPUT);
  //Setup averaging arrays
  int i;
  for(i=0; i< ARRAY_SIZE; i++)
    therm1[i] = 512;
    therm2[i] = 512;
    humval[i] = 735;
    carbonD[i] = 645;
  //pinMode(BACKLIGHT,OUTPUT); Backlight on all the time, so comment out this.
  lcd.init();
  lcd.clear();
  digitalWrite(BACKLIGHT,HIGH);
  //Start serial comms with computer
  key = get_key(adc_key_in); //In case
  //reset sensor_check if millis() has overflowed
  if( millis() < sensor_check ){ sensor_check = millis();  }
/* This is for backlight off delay.
  if ( (millis() < backlight) || millis() > (backlight + BACKLIGHT_TIME))
  { digitalWrite(BACKLIGHT,LOW); }
  /*Read sensor only after delay of sensor_check*/
  if(millis() - sensor_check > SENSOR_INTERVAL )
    int i;
    for (i=0; i < ARRAY_SIZE -1 ; i++) {
      therm1[i] = therm1[i+1];
      therm2[i] = therm2[i+1];
      humval[i] = humval[i+1];
      carbonD[i] = carbonD[i+1];
    /*** Read in sensor values and change to fit actual temp/hum/ppm values*/
    therm1[ARRAY_SIZE -1] = analogRead(THERM1);
    int temp1 = mov_avg(therm1);
    thermValue1 = (temp1 - TEMPERATURE_C)/TEMPERATURE_M; // x = (y-c)/m
    therm2[ARRAY_SIZE -1] = analogRead(THERM2);      //thermValue2 = analogRead(THERM2);
    int temp2 = mov_avg(therm2);
    thermValue2 = (temp2- TEMPERATURE_C) /TEMPERATURE_M;
    int hum_temp = pulseIn(HUMIDITY2,HIGH,2000); //
    if (hum_temp > 40 )  //Remove some non readings which give huge negative numbers
      humval[ARRAY_SIZE -1] = hum_temp;
      hum_temp = mov_avg(humval);
      humValue = (hum_temp - HUMIDITY_C)/HUMIDITY_M; // y -c/M = x
int c_temp = analogRead(CARBONDI3);
    Serial.print(c_temp);
   /*if (( c_temp > 0 ) && (c_temp <300))      //stops unecessary calcs which grind arduino to a halt
      carbonD[ARRAY_SIZE -1] = c_temp;
      c_temp = mov_avg(carbonD);
      Serial.print(":");
      float c_float = c_temp - Carbon_C; // For ease of use in power function
      c_float = c_float/Carbon_M;
      Serial.print(":");
      Serial.print(c_float);
      carbonDiVal  = pow(2.718,c_float);
    Serial.print(":");
    Serial.println(carbonDiVal);
    /**Add first line of Display**/
    if (configure == 0)
      lcd.cursorTo(1,0);
      lcd.printIn("T1 T2 Hu CO2");
    /**** Add second line of the Display *****/
    if (configure == 0)
      lcd.cursorTo(2,0);
      itoa(thermValue1, buf, 10);
      lcd.printIn(buf);
      lcd.cursorTo(2,3);
      itoa(thermValue2, buf, 10);
      lcd.printIn(buf);
      lcd.cursorTo(2,8);
      lcd.printIn(" ");
      lcd.cursorTo(2,6);
      itoa(humValue, buf, 10);
      lcd.printIn(buf);
      lcd.cursorTo(2,12);
      lcd.printIn("  ");
      lcd.cursorTo(2,9);
      itoa(carbonDiVal, buf, 10);
      lcd.printIn(buf);
The code goes on but this is where all the errors are.
Jimmy60
You have lcd.printIn with an I (an eye) it's probably lcd.println with an L (actually lower case L).
I had no problems with the serialLCD.h library. It only has a print function not a println, which I don't see much need for on a 16x2 display.
PaulS
Quote
No errors are "better" than other errors. "No errors" is better than "any errors".
What part of those messages do you not understand? You seem to be trying to use a NewSoftSerial instance as though it was an LCD. You can't do that.
You can use NewSoftSerial to talk to an LCD, if it is a serial LCD, but that is going to require either that you understand what to send to the LCD to make it do stuff, OR a change to the library to make it use a software serial port, instead of the hardware serial port.
I'd suggest that you go study this page:
http://www.arduino.cc/playground/Learning/SparkFunSerLCD
AlanFFM
Once again thank you all for the help.
I've finally been able to compile the code with no errors, however it dosetn work. I'm 99.9999% sure its because i removed some .. important values...
a recurring error was
lcd.cursorTo(1,0);   for example, the numbers were different in each line this happened in,
I changed all of them to
lcd.cursor();   and it worked...
but obviously those numbers were important ( think they were for the relays).
btw thanks for the print info. replaces the i's with l's worked :)
PaulS
cursor() turns the underline on. noCursor() turns it off. cursorTo() positions the cursor. The functions are not interchangeable.
AlanFFM
Jimmy60
The location you want to move the cursor to before printing. IIRC it's position and line. Positions from 0..15 and lines 0 and 1. (My apologies if it's actually vice versa.)
AlanFFM
ok so i went back to do the lcd cursorTo command and got errors again :(
sketch_oct16a:279: error: 'class serLCD' has no member named 'cursorTo'
Jimmy60
You might want to post your current code.
AlanFFM
Part 1
Code: [Select]
#include <serLCD.h>
#include <SoftwareSerial.h>
#include <EEPROM.h>
/* Temperature, Humidity and C02 Environmental controller
Written for use in mushroom cultivation.
Written by Anthony Pino. anthony_p1234@yahoo.com
Please feel free to use this code chop change etc...
I take no responsibility for this code blowing up your arduino.
Basically, this program takes in 3 analog inputs, Temperature 1, Temperature 2, C02 and 1 Digital input
Humidity. Then switches on/off 4 corresponding digital outputs.
Temperature 1 - Thermistor (voltage)
Temperature 2 - Thermistor (voltage)
Humidity - Capacitor (frequency change given by a change in capacitance in a 555 timer circuit)
C02 - Gas sensor (voltage change, amplified using a precision op-amp)
Digital outputs are intended to be connected to high voltage relays to switch heaters
air pumps and humidifiers etc. Please be carefull when using high voltage.
This code uses the LCD Shield. Normal display shows current readings, Asterixes to the
right of the display show if one of the relays is on HIGH.
Pressing button 1 toggles configure mode, where up down (button 3+4) buttons change the triggering values
of the relays. T1,T2,Humidity relays triger when bellow trigger values, C02 relay triggers when above trigger
value.
Pressing button 5 scrolls through the trigger values.
Pressing button 1 again returns to normal display.
Button 2 not used as mine did not work on the LCD shield, feel free to add it.
Values are kept in EEprom for the last 1.34 days. Pressing Right button when in
normal mode pushes it to serial tx. Good for plotting on a xls spreadsheet to see what the values
were.
/* Humidity Calibration
Hum     Time between pulses
75%            788.4
100.00% 840
y = mx +c ,
Where y = Time to between up pulses, x = humidity value
#define HUMIDITY_C  680 //668
#define HUMIDITY_M 1.6 //1.72
/* Temperature/Thermistor Calibration
5v--100k_Therm--input--100k --gnd
y = bit value from input, x = Temperature Value
y = mx +c    */
#define TEMPERATURE_M 13.31
#define TEMPERATURE_C 188.1
/* Carbon dioxide calibration
y = MLogn(x) + C
x = e^((y-C)/M)
where y is bit value and x is c02 concentration
C02 Bit Value
400 279.98
10000 -0.03
  =-87*(LN(N25))+800
#define Carbon_M -83.45 // was-87
#define Carbon_C 768.62 //was 800
/* Interval Definitions*/
#define INTERVAL 30000 //Define ms INTERVAL in between trigerring
#define SENSOR_INTERVAL 400 // SENSOR INTERVAL
#define BACKLIGHT_TIME 180000 // 1 minute for backlight on after no keypress. NOT BEING USED NOW
#define EE_PROM_INTERVAL 600000 //write data to eeprom every 10minutes
/*Define array size to be used for averaging. */
/*In The array, the max value and min value are taken out and the rest averaged*/
/* If 2 or less, it is just averaged*/
#define ARRAY_SIZE 30
/*Hysterisis Intervals*/
#define TEMP_LO 1
#define TEMP_HI 2
#define HUM_LO 5
#define HUM_HI 0 //trimmed as tends to overshoot
#define CO2_LO 200
#define CO2_HI 100
/* Define input Pins  */
//Analog
#define THERM1  1    // Analog 1 Thermistor 1   voltage
#define THERM2 2    // Analog 2   Thermistor 2 Voltage
#define CARBONDI3 3 // Analog 3
// Digital
#define HUMIDITY2 2 // Digital 2 Humidity
/*Define output  Pins */
//Digital
#define LEDPIN  13     // select the pin for the LED
#define RELAY1  3      // Relay to start the first heater
#define RELAY2  11      // Relay to start the second heater
#define RELAY3  12     //Relay to start the humidifier
#define RELAY4  13     //Relay to start air pump
#define BACKLIGHT 10   //backlight Pin Value
//Can use pins 0 + 1 if serial not being used.. or use an analog pin.
/******Define Size of storage array for values*/
#define ARRAY_STORE 200 //how many lines to store in eeprom. ARRAY_STORE*4 <1k
/*set Triggers *************/
int heatTrigger1  = 25;
int heatTrigger2  = 20;
int HumTrigger = 80;
int C02Trigger = 800;
/* Sensor Value initialize */
int thermValue1 = 0;
int thermValue2 = 0;
int humValue = 0;
int carbonDiVal = 0;
int therm1[ARRAY_SIZE];
int therm2[ARRAY_SIZE];
int humval[ARRAY_SIZE];
int carbonD[ARRAY_SIZE];
/*Set time check ms     */
long last_check = millis();
long sensor_check = millis();
long backlight = millis();
int timing = millis();
long time_eeprom = millis();
/** LCD Shield            */
serLCD lcd(13); // use both lines
int NUM_KEYS = 5;
int key= -1;
  "Temp Trigger 1",
  "Temp Trigger 2",
  "Humid Trigger",
  "C02 Trigger" };
int k=0;
  //pinMode(LEDPIN, OUTPUT);
  int i;
    therm1[i] = 512;
    therm2[i] = 512;
    humval[i] = 735;
    carbonD[i] = 645;
  lcd.init();
  lcd.clear();
    int i;
AlanFFM
Part 2
Code: [Select]
      Serial.print(":");
      Serial.print(":");
    Serial.print(":");
    if (configure == 0)
      lcd.cursorTo(1,0);
      lcd.println("T1 T2 Hu CO2");
    if (configure == 0)
      lcd.cursorTo(2,0);
      lcd.println(buf);
      lcd.cursorTo(2,3);
      lcd.println(buf);
      lcd.cursorTo(2,8);
      lcd.println(" ");
      lcd.cursorTo(2,6);
      lcd.println(buf);
      lcd.cursorTo(2,12);
      lcd.println("  ");
      lcd.cursorTo(2,9);
      lcd.println(buf);
    /*Print Output Values*/
Serial.print(thermValue1);
     Serial.print(":");
     Serial.print(thermValue2);
     Serial.print(":");
     Serial.print(hum_temp); //usually humValue
     Serial.print(":");
     Serial.print(carbonDiVal);
     Serial.println(":");
    /* PRINT ARRAYS THAT ARE AVERAGED
     Serial.print("**Therm1*");
     Serial.print("*(");
     for( i=0; i<ARRAY_SIZE; i++)
     Serial.print(therm1[i]);
     Serial.print(":");
     Serial.print(")**Therm2*");
     Serial.print("*(");
     Serial.print(therm2[i]);
     Serial.print(":");
     Serial.print(")**Humid*");
     Serial.print(humValue);
     Serial.print("*(");
     Serial.print(humval[i]);
     Serial.print(":");
     Serial.print(")**carbonD*");
     Serial.print("*(");
     Serial.print(carbonD[i]);
     Serial.print(":");
     Serial.println(")");
  /*EEPROM STORAGE CODE   *********************/
  if(millis() < time_eeprom) { time_eeprom = millis(); }
  /**Put values into eeprom*/
  if(millis() - time_eeprom > EE_PROM_INTERVAL)
    EEPROM.write((k*4),(thermValue1));
    EEPROM.write((k*4+1),(thermValue2));
    EEPROM.write((k*4+2),(humValue));
    EEPROM.write((k*4+3),(carbonDiVal/10));
    k=k+1;
    if(k>=ARRAY_STORE) { k=0;  }
/*RELAY Changes and value checks, after time INTERVAL***/
  if( millis() < last_check ) { last_check = millis(); }
  if (millis() - last_check > INTERVAL)
    last_check = millis(); //left out until final test, no wait 30sec
//Temperature 1 check and Relay Change
    lcd.cursorTo(1,14);
    if (thermValue1 > (heatTrigger1 +TEMP_HI) ) {
      digitalWrite(RELAY1, LOW);
      lcd.println(" ");  }
    if (thermValue1 < (heatTrigger1 -TEMP_LO) ) {
      digitalWrite(RELAY1, HIGH);
      lcd.println("*"); }
//Temperature 2 and Relay Change
    lcd.cursorTo(1,15);
    if (thermValue2 > (heatTrigger2 +TEMP_HI) ) {
      digitalWrite(RELAY2, LOW);
      lcd.println(" ");}
    if (thermValue2 < (heatTrigger2 -TEMP_LO) ) {
      digitalWrite(RELAY2, HIGH);
      lcd.println("*"); }
//Carbon Dioxide check and Relay Change
    lcd.cursorTo(2,15);
    if ( carbonDiVal < C02Trigger- CO2_LO  ) {
      digitalWrite(RELAY4, LOW);
      lcd.println(" ");  }
    if ( carbonDiVal > C02Trigger+ CO2_HI  ) {
      digitalWrite(RELAY4, HIGH);
      lcd.println("*");  }
//Humidity Check and Relay change
    lcd.cursorTo(2,14);
    if ( (humValue > HumTrigger+ HUM_HI ) || (humValue == -HUMIDITY_C)) {
      digitalWrite(RELAY3, LOW);
      lcd.println(" "); }
    if ( (humValue <= HumTrigger - HUM_LO ) && (humValue != -HUMIDITY_C)) {
      digitalWrite(RELAY3, HIGH);
      lcd.println("*");}
/*KEYPAD CODE***************/
  adc_key_in = analogRead(0);
  key = get_key(adc_key_in); //convert into key press. key = 1-5. -1 for none
  if ( (key != -1))
  /*  digitalWrite(BACKLIGHT,HIGH); //Backlight code taken out
    backlight = millis();*/
    if (configure ==1)
    { lcd.clear();  }
    delay(20); //debounce
    delay(200);
    /****Select key****/
    if ( key == 3 ) //Toggle the configure Key
      lcd.clear();
      if( configure == 1)
        configure = 0;
        lcd.clear();
        delay(100);
      else if ( configure == 0 )
        configure = 1;
        lcd.clear();
        delay(100);
      key = -1;
