Loading...
Pages: 1 [2]   Go Down
Author Topic: standalone programmer  (Read 1007 times)
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Yes, just uploading a sketch.
Thanks Nick, I'll do some more browsing.
There's 4 SUT choices.
Clock source is very confusing. There are 2 choices of Low Power Crstal Oscillator 8-16 MHz.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Success!  Took a bunch of flipping back & forth within screens and to the fuse calc page, was finally able to get the fuses displayed
LFuse = FF
HFuse = DE
EFuse = FD
Lock byte = CF
No JTAG
ATMega328
Fuse Enable
HEX file as selected
Lock Bits - No protection
Application Boot Block Lock Bits - No Restrictions
Boot Loader Boot Block Lock Bits - Mode 3 = Mode 2 + 4
Enable Boot Block Reset Vector
Clock - 1111 Low Power Crystal Oscillator 8-16 MHz
Startup Time - SUT 11
Boot Block Size - 256 Words
Selected Medium Fast for programming speed
Vcc - 5V
Connected ICSP header - pushed the button - bunch of flashing occurred, then a Green LED.
Connected the board to its circuit (ribbom cable to LEDs, power) - powered up & it seems to work!
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Sounds like a fun product. smiley
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Yes, end company using it will have no problem using it. Plug header onto ICSP connector of standalone board, push the button, 8 seconds later its all done.
Found out after we ordered the programmer that uCs will be pre-programmed before being installed onto boards in India.
Programmer will be a backup I guess in case programming needs to change after boards are provided to be assembled into end product.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
