Topic: Sending IR commands to Robosapien from Arduino (Read 1 time) previous topic - next topic
MV
Hello,
I am trying to send IR commands to a Robosapien (first generation) but I am unable to get any response from the toy.
I read that in order to send a code like 0x85 (right-arm-in), you have to send:
Binary: 1 0 0 0 0 1 0 1
IR Code: 1110 10 10 10 10 1110 10 1110
(ie., a '1110' for a '1' and '10' for a '0')
Also, I read that you have hold the input high and send a string of five '0' pulses before sending a command.
So accordingly, I tried the following code:
Code: [Select]
int bitTime=833;
int IROut =  4;
// The setup() method runs once, when the sketch starts
void setup()   {
  // initialize the IR digital pin as an output:
  pinMode(IROut, OUTPUT);
// This procedure sends a 38KHz pulse to the IRledPin
// for a certain # of microseconds. We'll use this whenever we need to send codes
void pulseIR(long microsecs) {
  // we'll count down from the number of microseconds we are told to wait
  cli();  // this turns off any background interrupts
  while (microsecs > 0) {
    // 38 kHz is about 13 microseconds high and 13 microseconds low
   digitalWrite(IROut, HIGH);  // this takes about 3 microseconds to happen
   delayMicroseconds(10);         // hang out for 10 microseconds, you can also change this to 9 if its not working
   digitalWrite(IROut, LOW);   // this also takes about 3 microseconds
   // so 26 microseconds altogether
   microsecs -= 26;
  sei();  // this turns them back on
void test()
  // send high
  //pulseIR(
  pulseIR(1000*bitTime);
  for(int i = 0; i < 4; i++) {
    delayMicroseconds(bitTime);
    pulseIR(bitTime);
  // burp: C2
  // 1 1 0 0 0 0 1 0
  // send 1110 1110 10 10 10 10 1110 10
  pulseIR(3*bitTime);
  pulseIR(3*bitTime);
  pulseIR(bitTime);
  pulseIR(bitTime);
  pulseIR(bitTime);
  pulseIR(bitTime);
  pulseIR(3*bitTime);
  pulseIR(bitTime);
  // wait for 1 sec
  test();
But I don't get any response. I'd appreciate any helping in sending the IR codes to the robot.
Thanks
MV
http://tat-tvam-asi.in/
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
