Topic: I'll be honest. (Read 6035 times) previous topic - next topic
Grumpy_Mike
Well no, 30watt CPU dissipates how much heat?
So a 30watt cpu that is also a superconductor with no energy loss... a 30watt CPU becomes a 0watt cpu. right? no losses to heat at all.
Super Computers on your wrist.
Sorry I don't think you understand CPUs or super conductors if you think that.
cyberteque
Re: superconducting semiconductor.
http://en.wikipedia.org/wiki/Josephson_effect
It works a bit like a FET or valve.
Cray stopped research ages ago, but they principle has been applied in making standard voltage cells, SQID's and single electron transistors.
The frequency of the "gate" current vs the voltage across the junction is very linear.
Building an amplifier where the gain is controlled by gate frequency rather than voltage or current sounds really tricky.
Re: Toothache
Try clove oil or cinnamon stick, both are good topical anesthetics.
Re: rude/nasty comments about smoking weed
(insert comment the moderator won't like, something about erectile dysfunction, procreating with animals/one's self, general shortsightedness, believing everything the government says)
Boffin1
Strangely enough, I have a connection between superconduction, and substances that make you do dopey things :-
While working in a hut  at the Radio and Space Research Station in the UK in 1970, I had to fill a dewar ( like a vacuum flask ) with liquid helium ( we had a superconducting coil around a crystal at - 269 deg C , to detect a laser beam )
The liquid helium was in a dewar  inside another dewar of liquid nitrogen, and to get it into the detactor dewar, I had a bottle of normal helium, to push it up the pipe.
The phone in the hut rang ,  I had a bottle of helium  -  well, who could resist it ?
I answered the phone in a chipmunk voice,  and it was the Director looking for my team leader !      who needs dope to feel stupid ?
45 years of editing projects with a knife and soldering iron, then I found Arduino !
Grumpy_Mike
Quote
Ah, reasoned debate, that is what we all need.
Which government are we talking about here?
P18F4550
Quote
Could be any.
It's easy to tell when a politician is lieing, their lips move
