Loading...
Pages: [1] 2   Go Down
Author Topic: On one line  (Read 554 times)
Offline Offline
Newbie
View Profile
I want to put this on one line.
pinMode(2, OUTPUT);
All the way through to pin 10. Can it be done?
Also, digitalWrite(2, LOW);
All the way through to pin 10. Same?
Logged
France
Offline Offline
God Member
Scientia potentia est.
View Profile
Using a for loop:
Code:
for ( byte i = 2; i <= 10; i++ )
  pinMode( i, OUTPUT );
  digitalWrite( i, LOW );
Well not really one line but almost smiley
« Last Edit: October 12, 2012, 12:07:02 am by guix » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Modifying guix's suggestion:
Code:
for ( byte i = 2; i <= 10; i++ )  pinMode( i, OUTPUT );
One line. smiley-razz
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
And without spaces?
Code:
for(byte i=2;i<=10;i++)pinMode(i,OUTPUT);
Logged
Offline Offline
Newbie
View Profile
All right already! The big bad FOR shows it head again!
Thought I could do it with these things:  (   ),    [   ],    {   }
But, guess not.
Thanks all... smiley
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You can invent your own language if you like:
Code:
pinMode ( { 2 .. 10 } , OUTPUT);
But it isn't C.
Quote
Loops are a fundamental part of programming. May as well accept it.
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
If that worries you you're going to have a hard time programming smiley
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Edison Member
View Profile
Quote
How about this?
Code:
pinMode(2, OUTPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT); ...., pinMode(10, OUTPUT);
If those pins are all on the same port, you can ever do it with one statement.
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
Not if you want the code to stick to using the Arduino core code routines and remain portable
across other boards that use different processors or different variants, i.e.
Arduino Uno vs Arduino Leonardo vs Mega vs Teensy vs Sanguino, Chipkit, Maple, and if it is ever released, Arduino DUE.
--- bill
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
And without spaces?
Please don't to that. Too much unreadable code is already posted here.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Just being playful PaulS. I don't recommend putting it all "on one line" anyway.
Reply #1 is the recommended answer.
Logged
Offline Offline
Newbie
View Profile
Quote
Hey, I've learned a lot. And I'm not worried about FOR. We all use it many times. Probably a bit over the top me saying "big bad for".  Reply # 1 looks good. Just thought I could conserve some ink. I'm done! Thanks all.
Logged
Finland
Offline Offline
Sr. Member
Arduino rocks
View Profile
But, guess not.
If you hate "for", use "while" instead:
Code:
byte i=2; while (i<=10) pinMode(i++,OUTPUT);
Logged
Finland
Offline Offline
Sr. Member
Arduino rocks
View Profile
You can also use direct port manipulation without fors or whiles:
Code:
DDRD = DDRD | B0111111;  // pins 2-7
DDRB = DDRB | B10000000; // pin 8
Logged
Offline Offline
Newbie
View Profile
Quote
And:
Quote
WOW ! 2 other ways. Super   smiley
« Last Edit: October 14, 2012, 11:15:46 pm by donde » Logged
Pages: [1] 2   Go Up
Print
Jump to:
