Topic: UNO board doesn't work unless monitor is running (Read 996 times) previous topic - next topic
Bitcosoftware
Has anyone seen this issue... I have an uno board, connected to windows XP.  I am connected with the USB cable with a simple connection of three wires in ports 2,3,4 that are running to 2 - 8 bit shift registers running 16 LED's.  I am creating a binary clock.
The code runs through shifting the registers based on the time.  When I am connected through the USB it will upload and try to run.  The lights will start flashing and then it seems to reset and flash again, over and over.  If I open the serial monitor it then runs correctly.
If I unplug the USB and then run it off of a 9v power supply it also runs correctly.
Any ideas?
CrossRoads
Not without seeing your code & schematic.
Could be overtaxing the 500mA available from the USB. Not sure why serial monitor would help that.
