Topic: Apprentice coder (Read 15048 times) previous topic - next topic
Pedro147
Being relatively new to Arduino I am trying to come to grips with the coding side of things. With regard to the following code
   #include "LedControl.h"
int timer = 50;
LedControl lc=LedControl(12,11,10,1);
  lc.shutdown(0,false);
  lc.setIntensity(0,5);
  lc.clearDisplay(0);
void down()
  for(int row = 0; row < 8 ; row ++)
    for(int col = 0; col < 8; col ++)
      lc.setLed(0,row,col,true);
      delay(timer);
void up ()
  for(int row = 7; row >=0; row --)
    for(int col = 7; col >=0; col --)
      lc.setLed(0,row,col,false);
      delay(timer);
void loop ()
    down ();
  //  lc.clearDisplay(0);
  up ();
Which as I am sure you can see is to control an 8 x 8 LED matrix with a Max 7219 progressively lighting the LED's from position (0, 0) to LED at position (7, 7) the top row of the matrix being LED (0, 0) TO LED (0,7) and then once all 64 LED's are on, turning them off one by one back to the starting position.
With regard to the first two for loops, in the void  down () function, presumably in the first for loop, int row = 0; initialises the row counter variable as zero, then row < 8 ; is the test condition which is true, so the code moves to the second for loop and goes through the same procedure for the columns and if this test is also true then the code lc.setLed(0,row,col,true); is executed lighting the LED at position (0, 0) then implementing delay(timer);
What I am having trouble understanding is why the code for the columns, increments from column 0 to column 7, before the first for loop then does it's first increment from the initialised row 0 to row 1, prior to the second for loop again incrementing through columns 0 to 7.
I think I understand the basic sequence of events in one for loop but two nested like this is confusing me. Can anyone please take a few minutes to try and explain the sequence of decisions that this code executes.
Thanks for reading and I hope my rambling description makes sense,
Pedro.
http://www.pedroduino.com
AWOL
#1
Oct 12, 2012, 08:39 am Last Edit: Oct 12, 2012, 08:42 am by AWOL Reason: 1
I'm not sure I understand the question.
You can only do one thing at a time, so scanning is this way seems, to me, perfectly natural.
When you read a page of text, you scan the words first across the line, then down the page.
Pedro147
I realise that this is normal behaviour but what I am trying to ask is why the code "uses" row 0 then goes to the columns "for loop" lighting all LED's in the row 0 and then incrementing the row counter to row 1 and lighting all the LED's in row 1. Why does the code remain in the column "for loop" incrementing from col 0 to col 7 before going back to the row "for loop"
AWOL
Because when you're reading a page of text, you read the columns (words) across the page, before going on to the next row of words.
Pedro147
#4
Oct 12, 2012, 10:01 am Last Edit: Oct 13, 2012, 01:19 pm by Pedro147 Reason: 1
I don't mean to sound like a simpleton  :smiley-mr-green: but if you read a page you go through it from start to finnish without going back and repeatably reading one particular passage. This is what is what I am not getting. Do not some sections of code execute what is "in the curly brackets"and then go back to the for loop that initiated them until that loop cannot logically execute what is "in the curly brackets" and then either go onto the next section of code in void loop or back to the start of void loop. Thanks for trying to help me with this I appreciate your time.
AWOL
Does this help?
The first clause of any "for" loop is executed only once.
Think of it like this:
int row = 0;
while (row < 8)
  int col = 0;
  while (col < 8)
    doSomething (matrix [row][col];
    col++;
  row++;
Now you can see that "row" is only initialised once.
That is exactly equivalent to two nested "for" loops
Pedro147
So am I right in looking at it like -
1.   the row counter is initialised at zero
2.   the column for loop initialises at col 0, then executes setLed progressively for all columns through to col 7
3.   the code then goes back to the first for loop where the row counter is now set to row 1
4.   the second for loop again executes setLed progressively for all columns through to col 7 but obviously now on row 1
5.     this continues until row 7 goes through the same routine and then the code moves to void down
AWOL
All correct, except for that very last bit.
It is function down, not void down.
Pedro147
I stand corrected AWOL  8)  I should know that it is a function. Thank you so much for taking the time to help me in my "quest to code"
Pedro
Pedro147
Would someone have a moment to explain to me why in this code there is a brief pause before the code resumes if I declare variable test in the for loop  as an int, whereas if I declare it as a byte there is no pause. Just curious thanks.
  int timer = 80;
    lc.clearDisplay(0);
  void loop ()
    for (int test = B00000001; test>0; test <<=1)
      lc.setColumn(0,1,test);
      delay(timer);
CrossRoads
Which has more bits to shift a 1 leftwards across:
B0000000000000001 (int, with upper 8 bits implied even tho not shown)
or
B00000001 (byte)
Pedro147
So moving a "1" leftwards across, is shifting 16 bits to the left before the "1"  comes back around, so to speak. But doesn't shifting a "1" to the right also also have to shift 16 bits to the right before comes back around (not doubting you obviously just trying to understand  :smiley-red:) or does it have something to do with the difference between declaring the test variable as int or byte? Is maybe the byte declaration shifting a whole byte at a time whereas the bit declaration is shifting one bit at a time. Thanks CR.
CrossRoads
It shifts left 16 bits - then it falls off the end,  test becomes 0,
the for:next loop ends,
and loop can start over with test = 1.
There's only something displayed while test is 00000001, 00000010, 00000100, 00001000, 00010000, 00100000, 01000000, 10000000.
While test is an int, there is no display while test is 000000010000000, out to 1000000000000000.
I don't see any shifting to the right.
Pedro147
#13
Oct 14, 2012, 05:30 am Last Edit: Oct 15, 2012, 04:25 am by Pedro147 Reason: 1
Of course, sorry I don't know how I came up with a shift right. Put it down to brain flatulence  8) As usual CR thanks for your time.
Pedro147
#14
Oct 26, 2012, 01:46 pm Last Edit: Oct 27, 2012, 04:34 am by Pedro147 Reason: 1
In my "quest to code" so I can stop pestering people on the forum to help me so much   :smiley-red: I have been trying to follow Grumpy Mikes tutorial at
http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
I did not have a seven segment display so I hooked six LED's up to digital pins 3 to 8 on an Uno and progressed through the tutorial until I successfully got to the stage of running this code.
 int timer = 100;
 int pins [6] = { 3, 4, 5, 6, 7, 8 };
 boolean led [6] = { HIGH, LOW, LOW , LOW, LOW , HIGH };
 void setup ()
   for(int i = 3; i < 9; i++) pinMode(i, OUTPUT);
  void loop ()
   for(int i=0; i<7; i++) digitalWrite(pins[i], led[i]);
The next stage of the tutorial expands the code to use char, a mask and a bitwise AND operation. So obviously I would need to incorporate this code into the previously posted code
char led = B10000001;
int mask = 1;
 if((mask & led) == 0) digitalWrite(pins[i], LOW);
else digitalWrite(pins[i], HIGH);
 mask = mask << 1;
I tried to put char led = B10000001; and int mask = 1; at the top of the code prior to setup and the if else and mask code into loop which did compile but did not light LED's 1 and 6 as hoped. I realise that this is a roundabout way to light two LED's but as I said at the start I am doing this to learn how to code and feel that this is an important coding technique to understand and use.
Thank you for taking the time to read this and hopefully explain what I am doing wrong,
Pedro.
