Canberra Australia
Enthusiastic Newbie
« Reply #60 on: November 02, 2012, 04:25:42 am » |
In Reply #44 I was asking how I might code the Knightrider type code to flash an LED sequentially x number of times while looping through the array. I have had some much appreciated help and have learn't some useful techniques but to be honest trying to work out how some of the sections of code work is perplexing to me. I have "dumbed down" version working but cannot work out how to efficiently code the digitalWrite HIGH/LOW and delay section of the code so that it turns the LED on then off "x" number of times. int timer = 300; int led[] = { 3, 4, 5, 6, 7, 8, 9, 10 }; int pinCount = 8;
void setup() { for(int i = 0; i < pinCount; i++) { pinMode(led[i], OUTPUT); } }
void loop() { for(int i = 0; i < pinCount-1; i++) { digitalWrite( led[i],HIGH); delay(timer); digitalWrite( led[i],LOW); delay(timer); digitalWrite( led[i],HIGH); delay(timer); digitalWrite( led[i],LOW); delay(timer);
{ for(int i = pinCount-1; i > 0; i--) { digitalWrite( led[i],HIGH); delay(timer); digitalWrite( led[i],LOW); delay(timer); digitalWrite( led[i],HIGH); delay(timer); digitalWrite( led[i],LOW); delay(timer); } } }
As I stated I do not mean to be unappreciative of the help I have received on this to date but if I cannot see how some code is working I will never progress and give you guys some piece and quite.  Thanks Pedro.
« Last Edit: November 02, 2012, 05:58:07 am by Pedro147 »
Norfolk UK
« Reply #61 on: November 02, 2012, 08:00:39 am » |
Hopefully just using lots of comments will help. A couple of possible errors in your code where the first and last LED will not turn on/off int timer = 300; // Delay time between LED turning on/off int led[] = { 3, 4, 5, 6, 7, 8, 9, 10 }; // Array of arduino pins the leds are connected to int pinCount = 8; // The number of LED's connected to pins
void setup() { for(int i = 0; i < pinCount; i++) // Loop through array from 0 to pinCount-1 { pinMode(led[i], OUTPUT); // Setting each pin to output } }
void loop() { for(int i = 0; i < pinCount-1; i++) // Loop through array from 0 to pinCount-2 (Should be i < pinCount) { digitalWrite( led[i],HIGH); // Turn LED i on delay(timer); // Delay a bit digitalWrite( led[i],LOW); // Turn LED i off delay(timer); // Delay a bit digitalWrite( led[i],HIGH); // Turn LED i on delay(timer); // Delay a bit digitalWrite( led[i],LOW); // Turn LED i off delay(timer); // Delay a bit } // Back for next i { // Not needed for(int i = pinCount-1; i > 0; i--) // Loop through array from pinCount-1 to 1 (Should be i >= 0) { digitalWrite( led[i],HIGH); // Turn LED i on delay(timer); // Delay a bit digitalWrite( led[i],LOW); // Turn LED i off delay(timer); // Delay a bit digitalWrite( led[i],HIGH); // Turn LED i on delay(timer); // Delay a bit digitalWrite( led[i],LOW); // Turn LED i off delay(timer); // Delay a bit } // Back for next i } // Not needed } // Back to loop start
Des Moines, WA - USA
« Reply #62 on: November 02, 2012, 01:42:54 pm » |
In Reply #44 I was asking how I might code the Knightrider type code to flash an LED sequentially x number of times while looping through the array. I have had some much appreciated help and have learn't some useful techniques but to be honest trying to work out how some of the sections of code work is perplexing to me. I have "dumbed down" version working but cannot work out how to efficiently code the digitalWrite HIGH/LOW and delay section of the code so that it turns the LED on then off "x" number of times. ... snipped some code ... As I stated I do not mean to be unappreciative of the help I have received on this to date but if I cannot see how some code is working I will never progress and give you guys some piece and quite.  Thanks Pedro. A more useful approach (it seems to me) would be for you to ask questions, concerning the code given, as to what you do not understand. Given the function … void flashLED(uint8_t pin, int repeat) { for ( unsigned int i = repeat * 2; i--; ) { digitalWrite(pin, !digitalRead(pin)); delay(tmTENTH_SECOND); } }
Whenever 'digitalWrite', on a pin whose value is set as 'OUTPUT' with 'pinMode', is called it internally tracks the last value the pin was set to. 'digitalRead(pin)' reads the last value sent to 'digitalWrite' and returns it. The '!' in front of the 'digitalWrite' inverts the value returned. If 'digitalWrite' returned '0' it changes it to '1' and if it returned '1' it changes it to a '0'. '0' equals 'false' while any non '0' value equals 'not false' 'digitalWrite' then sets the new value which is the opposite of the current value toggling the LED from 'on' to 'off', 'off' to 'on' By the way LOW a synonym for '0' and 'HIGH' is a synonym for '1' DOes this clear anything up for you?
Canberra Australia
Enthusiastic Newbie
« Reply #63 on: November 02, 2012, 07:35:35 pm » |
Riva - Yes Riva regarding the comments, I know that I should have them (slaps back of own wrist  ) as they help to explain my intentions, and sometimes it's easy to forget what you were initially trying to achieve. With the actual pin Count reference in the two for loops of void loop Quote from your comment - for(int i = 0; i < pinCount-1; i++) // Loop through array from 0 to pinCount-2 (Should be i < pinCount) if I change pinCount - 1 to pinCount in both for loops LED's 1 and 8 will flash on / off four times each while LED's 2 - 7 still flash at the set rate of on / off twice, so I am a little confused there. Thanks for the help and in future I will comment on all my code. Lloyddean - So if I might paraphrase your explanation. In your flashLED function, you are setting pin to to a value opposite to what it was last set to. This is achieved by the ! in front of digitalRead. Effectively this function turns the LED on / delay / off , on / delay / off a number of times as dictated by the numeral 8 in this section of void loop - flashLED(pinsLEDS , 8 );
So in a basic digitalWrite you nominate a pin and then a value (usually HIGH or LOW) In your flashLED function you set the value via !digitalRead(pin) which inverts the last value of digitalWrite generating the "flashing effect"
The way that I am looking at it, that takes care of the "what to do" part of the function but the "when to do it" part -
and the -
sections still confuse me. I hope that from my explanation it sounds like some of your hard work here is starting to pay off. Thanks Pedro.
« Reply #64 on: November 02, 2012, 07:43:22 pm » |
and the -
So 'what' is it you're confused about. It would help you if you tried to be more specific in relating your confusion as it is very difficult to 'guess' and provide explanations that are useless to you. EDIT: void flashLED(uint8_t pin, int flash_count) { for ( unsigned int i = flash_count * 2; i--; ) { digitalWrite(pin, !digitalRead(pin)); delay(tmTENTH_SECOND); } } A flash consists of an 'ON' state of some length, followed by an 'OFF' state of some, perhaps equal, length. That's two separate state changes that need to occur eight time for a total of 16 state changes.
« Last Edit: November 02, 2012, 07:51:29 pm by lloyddean »
Canberra Australia
Enthusiastic Newbie
« Reply #65 on: November 02, 2012, 08:04:16 pm » |
Sorry I thought that my question was clear but obviously it was not.I will use the question marks so that no one thinks that I am stating a fact, only asking if I am correct. What does "void flashLED(uint8_t pin, int repeat)" mean. Void means - returns no value ? flashLED - is the name of the function ? uint8_t and int - are data types ? In the for loop what does "repeat * 2" - * is a multiplier but that's all I understand here. Thank you for your patience and did it seem like I understood your explanation re the setLED function. EDIT - I just saw your edit so I will have to think about that too (and I thought that I was confused before  )
« Last Edit: November 02, 2012, 08:14:51 pm by Pedro147 »
« Reply #66 on: November 02, 2012, 08:11:31 pm » |
Your understanding of what the function does seems correct while your understanding of how to declare and or call functions needs work. None of that is meant to imply any kind of insult.
Since I'm not into writing long replies (and it's not that I don't think you're not worth the effort) I'll send you off to <http://www.cplusplus.com/doc/tutorial/functions/> for an explanation.
Please keep asking concerning things you don't understand.
Canberra Australia
Enthusiastic Newbie
« Reply #67 on: November 02, 2012, 08:19:24 pm » |
Thanks for your patience and the link to hopefully further understanding You are a good teacher and if I could give you an apple I would ( my Aussie sense of humour - we are a strange bunch down here)
« Reply #68 on: November 02, 2012, 08:26:26 pm » |
This is the beginnings of the actual definition of a subroutine, much like 'digitalRead' or 'delay'. The function returns a 'void', void meaning nothing is returned from the function. The name of the function is 'flashLED' and needs two parameters passed to it. The first parameter has a suggestive name of 'pin' and the second parameter a suggestive name of 'flash_count'. 'pin' specifies which pin the LED is connected to while the 'flash_count' communicates how many times the LED on 'pin' is to be toggled 'ON' and 'OFF'. EDITED:
« Last Edit: November 02, 2012, 08:39:49 pm by lloyddean »
Left Coast, CA (USA)
Measurement changes behavior
« Reply #69 on: November 02, 2012, 08:44:05 pm » |
This is the beginnings of the actual definition of a subroutine, much like 'digitalRead' or 'delay'. The function returns a 'void', void meaning nothing is returned from the function. The name of the function is 'flashLED' and needs two parameters passed to it, both of which are of type 'int' which are 16 bit signed values. Actually one parameter of type uint8_t and the second a type int.The first parameter has a suggestive name of 'pin' and the second parameter a suggestive name of 'flash_count'. 'pin' specifies which pin the LED is connected to while the 'flash_count' communicates how many times the LED on 'pin' is to be toggled 'ON' and 'OFF'. Not really 'suggestive names', but rather the actual names of the variables the function will use to utilize the values passed to them within the functions coding statements.
« Reply #70 on: November 02, 2012, 09:08:24 pm » |
More accurate would be - parameter name suggestive of implied use.
See <http://www.cplusplus.com/doc/tutorial/variables/> <http://www.cplusplus.com/doc/tutorial/constants/> <http://www.cplusplus.com/doc/tutorial/operators/>
« Last Edit: November 02, 2012, 09:12:18 pm by lloyddean »
Canberra Australia
Enthusiastic Newbie
« Reply #71 on: November 02, 2012, 09:52:26 pm » |
lloyddean I knew exactly what you mean't. I try not to be too pedantic  Thanks again, I'm playing around with inserting the digitalWrite ! digitalRead ( syntax ? ) into my code in progress, just need to nut out the flash_count aspect, although I will definitely be studying the cplusplus tutorials as I know my understanding needs vast amounts of improvement.
« Last Edit: November 02, 2012, 09:56:12 pm by Pedro147 »
« Reply #72 on: November 03, 2012, 01:21:08 am » |
Here are the declaration (as opposed to definitions) of some subroutines, functions, that you are more familiar with - void pinMode(uint8_t pin, uint8_t mode); uint8_t getPinMode(uint8_t pin); void digitalWrite(uint8_t pin, uint8_t val); int digitalRead(uint8_t pin);
Canberra Australia
Enthusiastic Newbie
« Reply #73 on: November 03, 2012, 03:02:11 am » |
Thanks for that and I am determined to get a firmer grasp of this.
« Last Edit: November 03, 2012, 06:55:41 am by Pedro147 »
Canberra Australia
Enthusiastic Newbie
« Reply #74 on: December 23, 2012, 10:15:24 am » |
I have been working on coding a 7 seg LED display to display from zero through to nine in a loop. As I am awaiting delivery of these displays, I am experimenting with using eight LED's in a row to display binary patterns approximating what will be required to display zero through nine when the 7 seg's arrive. The code that I am using is heavily based on Grumpy Mike's tutorial at http://www.thebox.myzen.co.uk/Tutorial/Arrays.html // Thanks to Grumpy Mike http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
int pins [] = { 2, 3, 4, 5, 6, 7, 8, 9 }; int digit[] = { 0, 1, 2, 3, 4, 5, 6, 7 }; int timer = 1000; char eightCode[] = { B01111110, B00110000, B01101101, B01111001, B00110011, B01011011, B01011111, B01110000 }; // Array element # 0 1 2 3 4 5 6 7
void setup() { for(int i = 0; i < 8; i++) // set digital pins as OUTPUTS pinMode(pins[i], OUTPUT); }
for(int j = 0; j < 8; j++) // loop through digit array { display8(digit[j]); // function to display elements of eightCode array delay(timer); // delay between displaying of eightCode elements
void display8(int num) { int mask = 1; for(int i = 0; i < 8; i++) { if((mask & eightCode[num]) == 0) digitalWrite(pins[i], LOW); else digitalWrite(pins[i], HIGH); mask = mask << 1; } }
I was just hoping that someone could have a look at the code and point out any glaring mistakes or improvements I could implement. It seems to be doing what I hoped it would do so I suppose that is a good sign.  Thanks Pedro.
