Topic: IDE Undo Redo is next to useless! (Read 6610 times) previous topic - next topic
Lakes
I can mostly get along with the IDE, but this one thing, I find most annoying....
If you want to go back several steps, the cursor does not move to show what you are undoing, so you can`t see what its doing!
So, I`ve had to save and save often, with a timestamp filename!
Visual Micro
#1
Oct 12, 2012, 12:29 pm Last Edit: Oct 12, 2012, 04:41 pm by Visual Micro Reason: 1
The Arduino IDE has been described as "cute". I think it's a safe word to use  :)
If you are using windows then grab a copy of Visual Studio Pro and the Arduino plugin from http://www.visualmicro.com
If you are using Mac then grab a copy of XCode and plugin from http://embedxcode.weebly.com/
If you are using Linux then use Eclipse and the Eclipse plugin http://eclipse.baeyens.it/
There is also a plugin for codeblocks and other dev tools.
Hope this helps
Arduino for Microsoft Visual Studio Pro and Atmel Studio 6.1 http://www.visualmicro.com
Arduino Debugger http://www.visualmicro.com/post/2012/05/05/Debug-Arduino-Overview.aspx
Graynomad
Yep, if you don't like the IDE (and you're not alone there) use something else.
There are the above options and also you can get the IDE to shell out to your own editor, that works pretty well.
_____
Rob
Lakes
Visual Studio looks good, I`ll watch the youtube tutorial, while its downloading. :)
Thanks!
eried
Wow, I never noticed this issue, it seems to be a common limitation in the UndoManager. I guess it can be fixed :D I will try to do it.
My website: http://ried.cl
Lakes
Minimal install of Visual Studio?
In the custom install what do I select?, I`m guessing I don`t need the silverlight and Web stuff...
Visual Micro
Except for Silverlight, it might all be useful.
The Visual Micro prerequisites state C#,VB.NET and C++ which allows you to build Arduino and also to create your own debugger visualizations.
The web stuff might be useful in the future for a remote monitoring system but it's up to you.
Jantje
Just for the record
If you like Eclipse you can use the Eclipse plugin http://eclipse.baeyens.it/ in windows mac and linux
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Lakes
I`v not used either, I`m just looking for something better than the very basic arduino IDE.
I`ll have a look at the eclipse IDE as well.
Lakes
Just for the record
Best regards
Jantje
Is this the correct link for the plugin?
http://avr-eclipse.sourceforge.net/wiki/index.php/Plugin_Download
There doesn`t seem to be a link to the plugin on your website that I could see.
Jantje
No it is not. The avr-eclipse is the basis for my plugin. It misses the easy to use features.
on my website http://eclipse.baeyens.it/
You can find the installation instructions http://eclipse.baeyens.it/Install.html
Eclipse has it's own way of installing plugins. This allows for easy upgrades to.
For a quick intro look at http://eclipse.baeyens.it/serial_demo.wmv
Best regards
Jantje
Lakes
Oh I see, you install the plugin from the IDE, ok thanks!
Lakes
Not sure whether to start a new thread about Eclipse or not, anyway...
The Preferences page is slightly different from your screen-shot to resolve the "serial" errors.
Version: Juno Service Release 1
Build id: 20120920-0800
There`s no "files to index up-front" in the preferences - indexer part
Jantje
#13
Oct 13, 2012, 10:34 pm Last Edit: Oct 13, 2012, 10:56 pm by Jantje Reason: 1
There is a thread on the eclipse plugin
http://arduino.cc/forum/index.php/topic,79595.0.html
I noticed this today as well. The reason is that what you see is in Juno while the other is in Indigo.
The bad news is : In Juno you can not set this option anymore
The good news is that after a compile and a rebuild of the indexer Juno sees the Serial.
Best regards
Jantje
Lakes
Ok, see you in the other thread! :)
