Topic: [SOLVED]LCD 16x2 showing garbage (Read 26143 times) previous topic - next topic
bluenomad
Got it.  The shield I'm using is this one: https://www.adafruit.com/products/243.  I set up the LCD using this tutorial http://learn.adafruit.com/character-lcds/wiring-a-character-lcd.   Of course I had suspected a conflict between the LCD and either the SD card or the Serial comm since I could place the LCD print code before initialization and it worked fine.  I searched around the net to find potential conflicting pins.  The last pin I changed was the DB7 from pin 12 to pin 0.  I also tried pin 1.  The results are the same. Text displays correctly at the beginning of the Setup() function but displays random characters that generally look alike if the code is placed below the initialization of either the SD or the serial.  I get that there are potential conflicts.  This is a community project and the others had earlier hardwired pins 2-4 so these are not an option.  I guess the question is, if the SD card uses pins 10, 11, 12, and 13; and the serial uses 0 and 1, and I'm already using 2-4 for the sensor, and 5,6,7, 8, 9 for the LCD, then the DB7 pin which was on 12 then I placed on 1, then 0 and I had the same results, then I'm stuck without any pins - unless I can use an analog pin, which I haven't tried yet.  BTW, the garbage was nothing near what it should have been, randomly place on the screen and odd ascii chars.
thx
NickPyner
The LCD is just a module and you should be able to wire it where you like, including the analogue pins, rather than suffer the constraints of a shield. I had a similar clash between an LCD shield and the SD. I was obliged to run a jumper across a proto shield and thereby use A2 (16) for the LCD.  The SD will surely use 11,1,2,13 but the select is usually on D4, so you need to be certain of that.
It can pay to use a spreadsheet with lots of colour in order to sort the pins out
liuzengqiang
The shield schematic clearly says D10-13 are used for the SD card and A4-A5 are used for real time clock. Then Leonardo uses D0 and D1 for hardware serial. Use any other pins, including A0-A3 analog pins. D4 is NOT used by the shield. Nick said with a "usually" which means he did NOT read the schematic, AGAIN!!!  :P :P :P
Here it is:
http://www.ladyada.net/images/logshield/logschemv1.png
You can also buy a backpack from my store to save all your pins:
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/serial-lcd-back-pack---phi-panel/
Will do you a lot good compared with its price.
BTW, is your RTC working? I suppose not but let me know. I have the same shield but don't have Leonardo.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
bluenomad
Guys, with  your help, I resolved it.  Here is the final config that worked: LiquidCrystal lcd(7,8,9,A2,A1,A0)
Karma, I love your backpacks - will pick a couple up.
Thanks.
floresta
Quote
That 'Karma' guy must have carpal tunnel syndrome by now.
Don
