Topic: SMS-Based LED Matrix Display. (Read 24288 times) previous topic - next topic
maskinao
Hi Guys. I'm working on a project, SMS-Based LED Matrix Display. this would display messages sent from a mobile phone to an LED matrix.
the GSM code can be found here: http://arduino.cc/forum/index.php?topic=126571.new;topicseen#new
And the LED-matrix part is attached in this message.
both work well independently, but when I integrate the two codes together and stacked the Arduino, GSM Shield and LED-matrix driver shield on one another, there's nothing being displayed on both Serial Monitor and LED Matrix. :(
I think there may be a Pin conflict? Hope you guys could help me out. thanks! :)
CrossRoads
What pins are being used? Review your different code listings and see which device is using what pin.
maskinao
for the LED-Matrix Driver, here are the pins i'm using and their pinModes.
Code: [Select]
const char CLK = 5;
const char DAT = 6;
const char STR = 7;
const char K0 = A0;
const char K1 = A1;
const char K2 = A2;
const char K3 = A3;
const char K4 = 8;
const char K5 = 9;
const char K6 = 10;
const char K7 = 11;
  pinMode(CLK, OUTPUT);
  pinMode(DAT, OUTPUT);
  pinMode(STR, OUTPUT);
  pinMode(K0, OUTPUT);
  pinMode(K1, OUTPUT);
  pinMode(K2, OUTPUT);
  pinMode(K3, OUTPUT);
  pinMode(K4, OUTPUT);
  pinMode(K5, OUTPUT);
  pinMode(K6, OUTPUT);
  pinMode(K7, OUTPUT);
  digitalWrite(K0,HIGH);
  digitalWrite(K1,HIGH);
  digitalWrite(K2,HIGH);
  digitalWrite(K3,HIGH);
  digitalWrite(K4,HIGH);
  digitalWrite(K5,HIGH);
  digitalWrite(K6,HIGH);
  digitalWrite(K7,HIGH);
as for the GSM, i'm not really sure. I used pins 2 and 3 to define TX, RX. does the GSM Shield other pins as well?
thanks!
- Migs
CrossRoads
Over in the other listing you have
Code: [Select]
#include <SIM900.h>
#include <sms.h>
#include <SoftwareSerial.h>
and
  if (gsm.begin(4800)){
I don't see where the pins are called out that these are using. So except for 0,1 for Serial.begin its hard to say.
How about listing all of the code here?
maskinao
Here's my code for GSM:
Code: [Select]
GSM BASED LED MATRIX DISPLAY USING ARDUINO
October 2012
#include <SIM900.h>
#include <sms.h>
// ---------- for sms ----------
char smsbuffer[160];    //holds buffered data
char smsdata[160];         //sms only accept 160 char, remaining for header
char numberRx[20];         //holds sender number
char incomingChar;
boolean started=false;
//---------- registered numbers ----------
char regnum[] = {"639339182267"};
char passRx[] = {"default#"};           //holds password, must be 8 char only! and ends with #
char parSMS[160];
void setup ()
  gsmsetup();
void loop ()
  checkSMS();
void gsmsetup(void)
// ---------- serial setup ----------
    Serial.println("GSM SHIELD READY");
    started=true;
  else Serial.println("GSM SHIELD IDLE");
void checkSMS()
// ---------- check if there is new message ----------
   if(started){
    if(gsm.readSMS(smsbuffer, 160, numberRx, 20))
      Serial.print("\nFrom: ");
      Serial.print(numberRx);
      Serial.print("\nMessage: ");
      Serial.print(smsbuffer);
      Serial.println("\n");
    checkSender();
void checkSender()
  char numRx[12];
  int p = sizeof(regnum);
  for (int x=0;x<=p;x++)
    numRx[x]= regnum[x];
  if (strncmp (numberRx, numRx, 11) == 0)
    Serial.println("Authorized Sender.");
    checkPassword();;
    Serial.println("Unauthorized Sender.");
void checkPassword()
  // ---------- check for password in string ------------
  if (strncmp (smsbuffer, passRx, 8) == 0)
    Serial.println("Password Correct.");
    parseSMS();
    Serial.println("Password inCorrect.");
void parseSMS()
  int y = 0;
  int i = 9;
  Serial.print("\nSMS Buffer: ");
  while (smsbuffer[i] != '\0')
    parSMS[y] = smsbuffer[i];
    Serial.print(smsbuffer[i]);
    i++;
    y++;
  loadSMS();
void loadSMS()
  int i = 0;
  Serial.print("\nParsed SMS: ");
    Serial.print(parSMS[i]);
    i++;
  Serial.println("");
Here's my code for LED Matrix Display
Code: [Select]
#include <DateTime.h>
#include <DateTimeStrings.h>
#include <stdio.h>
#include <stdlib.h>
#include "cmap.h"
unsigned int d;
unsigned char char_pointer;
char Display_Ram[38];
unsigned char mask;
int message_no;
char count;
unsigned char shift_counter;
#define INTEN 6500      //speed the higher the value, the slower the scroll
const char CLK = 5;
const char DAT = 6;
const char STR = 7;
const char K0 = A0;
const char K1 = A1;
const char K2 = A2;
const char K3 = A3;
const char K4 = 8;
const char K5 = 9;
const char K6 = 10;
const char K7 = 11;
  for(d=0;d<32;d++)
    clock();
  strobe();
  d = 0;
    DateTime.sync(DateTime.makeTime(0, 15, 10, 12, 9, 2012)); // default start, 00:00:00 at tuesday, october 9, 2012
  // sec, min, hour, date, month, year // Replace this with the most current time
  //  NOTE: month January starts from 0.
//   Serial.begin(9600);
void loop(){
//  unsigned long  prevtime;
//  if(DateTime.available()) { // update clocks if time has been synced
//   digitalWrite(13,LOW);  // first flash the LED
//   prevtime = DateTime.now();
//   while( prevtime == DateTime.now() )  // wait for the second to rollover
    DateTime.available(); //refresh the Date and time properties
  //  digitalClockDisplay( );   // update digital clock
  //  Serial.println("");
    // send our time to any app at the other end of the serial port
/*   Serial.print( TIME_HEADER,BYTE); // this is the header for the current time
    Serial.println(DateTime.now());
    digitalWrite(13,HIGH);  */
  Display();
  shift();
void shift(void)
  for (int val=0; val<37; val++){
    Display_Ram[val] = Display_Ram[val+1];
  shift_counter++;
  if(shift_counter == 6){
    shift_counter = 0;
    load();
void Display(void)
  mask = 0x01;
  scan();
  digitalWrite(K7,LOW);
  for(d=0;d<INTEN;d++){}
  mask = 0x02;
  scan();
  digitalWrite(K6,LOW);
  mask = 0x04;
  scan();
  digitalWrite(K5,LOW);
  mask = 0x08;
  scan();
  digitalWrite(K4,LOW);
  mask = 0x10;
  scan();
  digitalWrite(K3,LOW);
  mask = 0x20;
  scan();
  digitalWrite(K2,LOW);
  mask = 0x40;
  scan();
  digitalWrite(K1,LOW);
  mask = 0x80;
  scan();
  digitalWrite(K0,LOW);
void load(void){
  char counter1;
  char *LED_DATA= announcement(message_no);
  if(LED_DATA[char_pointer]  == '\0'){
    char_pointer = 0;
    message_no++;
    if (message_no >12){
      message_no = 0;
    goto exit;
  for(counter1 = 0; counter1 < 5; counter1++){
    //LED_DATA[char_pointer] - 0x20 =  ASCII code - 32
    //character_data[character/element from cmap.h][array in cmap representing each column]
    Display_Ram[32 + counter1] = character_data[(LED_DATA[char_pointer] - 0x20)][counter1];
  Serial.println(LED_DATA);
//  Serial.print("*****");
//  Serial.println(DateTime.Year,DEC);
  Display_Ram[37] = 00;
  char_pointer++;
  exit:
    counter1++; //do nothing
char *announcement(int message_no1){
//char *day_digit;
//itoa(DateTime.Day,day_digit, DEC);
char *Month_string = DateTimeStrings.monthStr(DateTime.Month);
//char *Day_string = DateTimeStrings.dayStr(DateTime.DayofWeek);
char *day_digit = convert_byte(DateTime.Day);
char *year_digit = convert_year(DateTime.Year-100);
char *min_digit = convert_byte(DateTime.Minute);
char *hr_digit = convert_byte(DateTime.Hour);
char *LED_message[]={"Today is ",
                     //Day_string,
                     Month_string,
                     day_digit,
                     year_digit,
                     "   Time: ",
                     hr_digit,
                     min_digit,
     "     LCoES Announcements            ",
     "Oct. 11-17 Final Examination       ",
                     "Oct. 18 Semestral Break       ",
                     "Enjoy your vacation!!!       ",
                     "See you next Semester       "};
return LED_message[message_no1];
char *convert_byte(byte number){
  char *digit[]={"00","01","02","03","04","05","06","07","08","09","10",
                      "11","12","13","14","15","16","17","18","19","20",
                      "21","22","23","24","25","26","27","28","29","30",
                      "31","32","33","34","35","36","37","38","39","40",
                      "41","42","43","44","45","46","47","48","49","50",
                      "51","52","53","54","55","56","57","58","59","60"};
  return digit[number];
char *convert_year(byte year_number){
  char *year_digit[]={"2000","2001","2002","2003","2004","2005","2006","2007","2008",
                 "2009","2010","2011","2012","2013","2014","2015","2016",
                 "2017","2018","2019","202","2021","2022","2023","2024"};
  return year_digit[year_number];
void Clear_Display_Ram(void){
  unsigned char rcount;
  for(rcount = 0; rcount < 37; rcount++)
    Display_Ram[rcount] = 0xff;
void scan(void){
  for (count=32;count>(-1);count--){
    if ((Display_Ram[count] & mask) == mask)
      digitalWrite(DAT,LOW);
      digitalWrite(DAT,HIGH);
    clock();
  strobe();
void clock(void){
  digitalWrite(CLK,HIGH); // clock hi
  digitalWrite(CLK,LOW);         // clock low
void strobe(void){
  digitalWrite(STR,HIGH); // strobe hi
  digitalWrite(STR,LOW); // strobe low
Hope you could help me. thanks!
CrossRoads
Quote
"but when I integrate the two codes together and stacked the Arduino, GSM Shield and LED-matrix driver shield on one another, there's nothing being displayed on both Serial Monitor and LED Matrix.
So where's the combined code?  That's what you're try to debug, yes?
maskinao
Quote
oh sorry. I used a simpler code first for the LED matrix, but it works in a similar way. then i combined it to the GSM code. here it is.
Code: [Select]
#include "cmap.h"
#include <SIM900.h>
#include <sms.h>
char incomingChar;
char parSMS[160];
int d;
unsigned char mask;
char count;
int newmessage = 0;
#define INTEN 6000
const char CLK = 5;
const char DAT = 6;
const char STR = 7;
const char K0 = A0;
const char K1 = A1;
const char K2 = A2;
const char K3 = A3;
const char K4 = 8;
const char K5 = 9;
const char K6 = 10;
const char K7 = 11;
  gsmsetup();
  pinMode(0, INPUT);
  pinMode(1, INPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  for(d=0;d<32;d++)
    clock();
  strobe();
  d = 0;
  Display();
  shift();
  newmessage++;
  if (newmessage == 500)
    checkSMS();
void gsmsetup(void)
    started=true;
void checkSMS()
   if(started){
    checkSender();
void checkSender()
  char numRx[12];
    checkPassword();;
    parseSMS();
void parseSMS()
  int y = 0;
  int i = 9;
    i++;
    y++;
  i = 0;
    i++;
  Serial.println("");
  newmessage = 0;
void shift(void)
  for (int x=0;x<37;x++)
    Display_Ram[x] = Display_Ram[x+1];
  shift_counter++;
    shift_counter = 0;
    load();
void Display(void)
  mask = 0x01;
  scan();
  mask = 0x02;
  scan();
  mask = 0x04;
  scan();
  mask = 0x08;
  scan();
  mask = 0x10;
  scan();
  mask = 0x20;
  scan();
  mask = 0x40;
  scan();
  mask = 0x80;
  scan();
void load(void)
  char counter1;
  if(smsdata[char_pointer+1] == '~')
    char_pointer = 0;
    Display_Ram[32 + counter1] = character_data[(smsdata[char_pointer] - 0x20)][counter1];
  char_pointer++;
void scan(void){
    clock();
  strobe();
void clock(void){
void strobe(void){
i'm getting fuzzy characters out of the LED Matrix. I'm guessing the GSM code and LED matrix can't run simultaneously, because i tired using loop statements before running the displays and it kinda worked.
- Migs
CrossRoads
To start:
"there's nothing being displayed on both Serial Monitor and LED Matrix."
and now:
"i'm getting fuzzy characters out of the LED Matrix. "
So some improvement?
and how about the serial monitor?
in void setup(), you call
Code: [Select]
  gsmsetup();
which then calls
so you might think pins 0,1 (serial) and 2,3 (gsm serial? still not seeing software serial setting up pins 2,3)
would be serial ports  - but then back in void setup you set those same pins as inputs
Code: [Select]
pinMode(0, INPUT);
  pinMode(1, INPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
which might be interfering with their use as serial ports.
maskinao
Quote
To start:
and now:
Yes Definitely. It's an improvement. Random display is better than no display at all. :D
Quote
pinMode(0, INPUT);
  pinMode(1, INPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
I actually just thought of utilizing those pins. but didn't use them anyway.
Quote
when i open the serial monitor, the LED matrix stop and turn off. but when I deleted the pinModes of 0-3, it worked, but now i'm getting a ON-OFF state LED Matrix with the same Random ASCII characters.
just a few more tweaks i guess! :) thanks!
- Migs
CrossRoads
I'm not seeing why the serial port has any impact.
maskinao
Quote
i'm not also sure why. When i start the program, the LED Matrix just displays the random character continuously. but when i open the serial monitor, it blinks and scrolls very slowly, around 30 seconds per dot.
could you see if there is a problem with this code?
Quote
void load(void)
  char counter1;
    char_pointer = 0;
  char_pointer++;
thats the one that locates the appropriate character on the character_data (CMAP.H)
CrossRoads
Maybe its just an overall use of SRAM?
I see you have a lot of arrays defined, some long serial.print messages.
How about shortening some of those up for testing?
maskinao
It partially worked last night. First it displayed the usual garbage, but when i sent a message to the GSM Shield, it displayed some text, then some garbage again. it displayed "639339182267<garbage>hello!<garbage>"
some improvement again i guess. :)
Quote
i'll try your suggestion. :) maybe it's consuming too much memory. But the sketch shows that i only consume around 11k when there's 32k available.
CrossRoads
"11k when there's 32k available.  "
That's Flash.
All the arrays & strings & variables are in SRAM.
You're using an Uno?  You've only got 2K.
maskinao
Quote
That's Flash.
oh. i see. how do i know how much SRAM i've consumed already?
