Topic: SMS-Based LED Matrix Display. (Read 21725 times) previous topic - next topic
invader7
yes i know that , but which part of the code loops through the messages ?  i want to see that code to help you
look for the shift and load functions. that's where the loop and shift happens.
i cant understand what are you doing at shift and loadSMS functions , can you sent me at a PM your logic with comments at these 2 functions ? and if i can i will help you
maskinao
Quote
the shift function "shifts" the characters from right to left. while the load locates the characters given to the CMAP.h header. read the whole thread to get the whole code.
thanks for trying to help, but i've got it. :) i'll post the code after some more changes. thanks anyway. :D
maskinao
Hi! I've got it working. it's 100%. :D
https://www.youtube.com/watch?v=WVhDr5CNxwE
i attached the code. :)
hope i contributed something to the Arduino Community. :)
you guys rock! thanks a lot!
guix
Good :)
I'm sorry that I led (:P) you in the wrong direction with my comment about pointers..
maskinao
Good :)
haha. i see what you did there. :) thanks! :D
cancerxin
pls help, " 'gsm' was not declared in this scope" i can't upload the code
cancerxin
#51
Nov 07, 2012, 11:36 am Last Edit: Nov 07, 2012, 11:39 am by cancerxin Reason: 1
Quote
im working same project, but i cant upload the the code i think because of the version of the arduino. im using arduino 1.0.1 pls help me  =(
maskinao
Quote
Hello. It's because you didn't download the proper libraries. Look for GSM/GPRS library made by open electronics and change the Tx Rx to 2 and 3 of the Gsm.cpp file
cancerxin
How can I solve this??
cancerxin
Quote
thank sir problem solved !!!!  :) :) :)
maskinao
Good job! Appreciate it if you left me some Karma points and some likes on Youtube. Hahaha. Thanks!
cancerxin
you saved my life sir  =(  :)
points for you  :)
cancerxin
#57
Nov 09, 2012, 05:05 am Last Edit: Nov 09, 2012, 06:06 am by cancerxin Reason: 1
sir I have problem, no text msg. appear in led matrix, only the first and 2nd msg are displaying.  :~ ???
http://www.youtube.com/watch?v=_HQjEAwLnOY&feature=youtu.be
pls check this.
maskinao
pls check this.
i think you have the wrong password. it should be "default#" without any spaces. maybe you've altered some part of the code i uploaded. there's something wrong with your checkSMS function of maybe you're text message is wrong.
and oh, i almost forgot, i think you didn't edit my number out. only my number is registered in the code i uploaded. i guess that will do the trick.
random question though: have you had extensive experience in programming?
cancerxin
i used my no. as the admin and the default# password,,, i will upload the codes
this is my first time in arduino :)
